Old 10-09-2010, 06:23 PM   #19
33OH
Drives: '08 Yaris
It's similar to the hub spacer DIY, you take off parts up to your hub and attach them. No disassembling of the rear shocks/springs.
Old 10-10-2010, 02:05 PM   #20
severous01
any alignment shop that uses hunter equipment has the shims you need and if you specify during the alignment that you want x.xx camber/caster/toe they can set it up how you want it. that's how it works with lowering...the company should have a card in there with new alignment specs for camber/caster. if the kit didnt come with new specs, it's probably not a very reputable company.
Old 10-11-2010, 01:01 PM   #21
edzzzzzzzzzz
NOOB :)
Drives: 2009 5-door hatch daily driver
first things first - why not?
next: a little negative camber in front (way less than you show for the rear in your picture) is GOOD for handling and DOES NOT affect tire wear (up to -1.5 is true for this statement), no matter what tires and wheels you are running.
So much misinformation gets posted on here. :: sigh ::
anyways, front adjustable camber bolts for the Yaris:
http://shop.microimageonline.com/Adj...olts-81270.htm
Thx Cali Yaris ! thats what am searching for, i have ordered longer bolts for my fronts, hopefully it'll be installed in a bout a week or so. just like what you said, am just adding a tad of negative camber.. should be fine for tires, but am just curious about how it'll look later on.
ill update with pics soon.. :)
edzzzzzzzzzz is offline   Reply With Quote
Old 10-11-2010, 01:02 PM   #22
edzzzzzzzzzz
NOOB :)
Old 10-11-2010, 01:04 PM   #23
edzzzzzzzzzz
NOOB :)
Lower more and get some wide, low offset rims. Then it'll fit more.
finally a support for what am trying to do hahaha, thx bud !
Old 10-11-2010, 03:46 PM   #24
No problem. Hellaflush is either a hate it or love it thing. More people hate it than love it tho. lol.
Old 10-20-2010, 06:41 PM   #25
docB
Drives: '09 Yaris Sedan
In the front, make sure the toe in is near zero if you kick in the negative camber. Toe is a big tread life killer.
doc
docB is offline   Reply With Quote
Old 10-23-2010, 07:41 PM   #26
gabriel2012
Drives: 2011 Base Sedan
according to the alignment computer in WesternAuto ( car came with alignment warranty from them) my car needed the bolts mentioned in this thread
this was my car with the stock bolts
after I got the new bolts installed the tires turned out to be straight in the alignment computer.
My concern is how long these new bolts will last :(
Edit: Ignore the date and time on the sheet the time settings are messed in the computer
gabriel2012 is offline   Reply With Quote
Adjustable Camber Bolts cali yaris Micro Image 30 12-11-2009 09:38 AM
New Product: Penguin Garage Rear Camber Shims! Penguin Garage Penguin Garage 11 10-22-2009 10:20 PM
DIY adding extra power outlets and usb power outlets on the dash to use phone as GPS julienrl DIY / Maintenance / Service 1 08-31-2009 10:06 AM
Are camber bolts needed after installing springs? CtrlAltDefeat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 02-01-2009 12:19 AM
Camber Plates (Gauging Interest) misformartin Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 01-07-2009 11:21 PM
