Old 10-24-2010, 01:37 PM   #9
Lil Abner
Drives: 2009 3dr LB Manual
The big problem I'm having is getting a beefy spring INSIDE the stock one. Still playing with that. Spring steel isn't the easiest to form, so that's part of the challenge.
Here is one attempt I'm trying today:
This is the clip that holds the spring to the bottom hinge side of the arm. As you can see, I bent it closer together, hopefully putting more load on the wiper arm. The weather is suppose to be rainy here the next couple of days, so I should be able to test it out on the highway. I sprayed some black paint on the bare metal from the vise I used. I'll let you know how it feels once I install it later today.
DIY - Standing rear wiper for hatchback sex DIY / Maintenance / Service 42 10-17-2018 06:32 AM
Wiper blades .... Lafiro General Yaris / Vitz Discussion 81 02-02-2012 06:54 PM
rear wiper arm delete Giammarco36 General Yaris / Vitz Discussion 20 05-16-2010 09:03 PM
How-To: Liftback Rear Wiper Arm - Full Pivot! Chris07LB DIY / Maintenance / Service 5 07-24-2009 03:08 PM
Anyone know how the passenger seat detection system works? rage2 DIY / Maintenance / Service 5 05-12-2007 07:22 PM
