Old 02-16-2011, 06:17 PM   #1
hayden
Drives: asd
I'm a little lost on this. I have an 07 3DR auto with no power options.
One of the wires goes from A21-pin 40 to pin 1 of D3. I haven't cracked it open to look yet, but I'm guessing this takes two of the three wires supplied (with a connector somewhere between the two)?
And I'm guessing I attach the wire that plugs into pin 2 of D3 to a ground point?
hayden is offline
Old 02-16-2011, 07:17 PM   #2
Correct - The one with the seal goes into A21 and the other two go into D3. One of the D3 pins connects to the A21 pin (you'll need to run a wire {18-22 AWG} between them). The other gets connected to a ground point under the dash.
CTScott is offline
Old 02-16-2011, 09:38 PM   #3
hayden
Drives: asd
So this kit doesn't come with everything needed, we need to buy additional 18-22AWG wire?
hayden is offline
Old 02-16-2011, 09:43 PM   #4
Correct. You'll need a piece of wire to connect the two ends and will either need to solder and heat shrink them or connect the two ends with butt splices.
CTScott is offline
DIY Cruise Control FAQ (2006-2010 Yaris) CTScott DIY / Maintenance / Service 468 11-19-2024 04:45 PM
radio wire colors & alarm wire color reference guide battleversiontc In Car Entertainment + Electronics (audio / video / alarm) 43 06-06-2023 03:12 PM
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 04:43 AM
Wires Inside the Yaris & What They Do The Architect DIY / Maintenance / Service 149 10-18-2022 04:32 AM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 04:55 PM
