#19 |
Going Retro
Drives: '09 Tacoma | '90 Tercel Join Date: Aug 2010
Would it make sense to do the clutch at the same time?
#20 |
100% yes.
Otherwise you're taking the transmission off twice. It still takes me about 2 hours to get the transmission off and on again and I know exactly what to do. I've done it about 4 times now. So if you're doing it yourself and you've never done a clutch or flywheel, you can bank on it being at least a 6-8 hour job. |
#21 |
UPDATE:
Forged steel remains in a solid state throughout the manufacturing process, maintaining a tighter grain structure resulting in higher performance loads. · Forging does not allow for porosity in castings and ensures a more reliable consistent material flow throughout the part. · Eliminates ring gear separation. · Eliminates friction surface and flywheel warpage. · One piece ring gear for high durability. · Stamped with 4140 forged plate with 2000 ton pressure at 1260 degrees. · CNC machined and balanced to OE specifications. · Meets and exceeds SFI 1.5 specifications. · The lightweight steel (heavier) version preserves low end torque and drivability. · All steel flywheels work with any performance and OE clutch assembly. ETA is about 30-45 days.
#22 | |
![]() ![]() ![]() Drives: 2005 Toyota Echo Join Date: Sep 2010
05' Echo Hatch - Greddy Supercharger - rear disc |
#23 |
UPDATE:
Flywheels are now in stock! And we got more good news. Besides the 9.64 lb light flywheel, we got an ultralight 8.64 lb flywheel -- that is the lightest made I'm pretty sure. Going up into the store as we speak.... woot!
#24 |
My Fidanza flywheel is 8.00 lbs. I weighed I on my digital kitchen scale. The stocker in the echo is a whopping 18 lbs.
#25 |
^ Those are both different numbers than the Yaris. Yaris stock is 15 pounds, and the Fidanza is 9-something.
#26 |
Here is the Ultralight version (8.64 lb):
#27 |
advocatus diaboli
If I was going to pair one of these flywheels with an aftermarket clutch, what stage clutch would you recommend and why?
Keeping in mind I use the car for high speed(whenever possible) long distance commuting, and stop and go LA traffic primarily.
#28 |
Depends on why you want a clutch. Just for more "grabbiness", or for a future mod that will actually require more clampng force?
#29 | |
advocatus diaboli
Besides price, are there disadvantages running something in preparation for more power, but far down the road? I'm worried about wearing out the performance clutch before I get around to the mod that requires it. I don't see my current clutch lasting that long so I'll have to pick the clutch long before I decide on the mod... supercharger v. turbo.
#30 | |
![]() but this one looks like it would make for faster revs because the majority of the mass is contained closer to the center than the Fidanza. |
#31 |
^ Yeah, agreed, I don't know either. Maybe we can compare pics of stock flywheels?
mazilla, The Clutchmaster Stage 3 is an awesome clutch that will last a very long time, and take just about whatever power you throw at it. I really like CM for their design, their clutches don't feel very stiff for the clamping force they deliver. And for their customer service. I can get the Stage 2, but with pedal feel the same, there's really no reason to go with that. I had an Exedy Stage II and that thing was just too stiff for the street. My CM Stage 4 by comparison gives an almost stock pedal feel. I should also be getting some CCI clutches that will be a better deal, but I haven't tried one so I can't say with confidence how it will actually feel.
#32 |
The Echo Flywheels for comparison
Fidanza ![]() Stock ![]()
#33 |
yep, that's quite a bit different than ours.
| Lightweight Flywheel for the Yaris? | NonStopTuning | Performance Modifications | 51 | 03-21-2014 02:57 PM |
| My review of the 2010 Kia Soul | Thirty-Nine | Off-topic / Other Cars / Everything else Discussions | 11 | 08-15-2009 02:51 PM |
| NST Now Offers Lightweight Flywheels ... Group Buy? | NonStopTuning | NonStopTuning | 25 | 07-17-2009 09:14 PM |
| lightweight flywheel from fidanza | dngz | Performance Modifications | 34 | 02-03-2009 11:02 PM |
| Review of the 2009 5-door and 3-door Yaris Liftbacks | csburdick | General Yaris / Vitz Discussion | 14 | 01-03-2009 07:09 PM |
