Old 05-07-2011, 10:24 AM   #1
Originally Posted by Bluevitz-rs View Post
Does it run through the coolant though? Or is it just a loop in front of the lower part of the rad. That makes a difference. If it's going through the rad the transmission temps should be pretty close to the coolant temps. If it's an open air loop in front of the lower part of the rad it won't be getting the airflow it requires.
The tranny cooler is part of the main radiator, but the tranny fluid temp should be cooler than the water temp, so I would think that the two sets of coils are isolated.
2007 Toyota Yaris Temperature Question bhola General Yaris / Vitz Discussion 17 06-25-2010 07:46 PM
Install Oil Pressure, Voltage and Temperature Gauges with DIY Holder bieniman DIY / Maintenance / Service 4 05-20-2009 12:40 AM
Temperature Guage install bieniman DIY / Maintenance / Service 3 03-12-2009 03:45 PM
Water temperature Bob_VT General Yaris / Vitz Discussion 11 11-03-2008 04:17 PM
