Old 07-25-2011, 01:42 AM   #1
T Pexx
Drives: 08' toyota yaris liftback
Question interior lights question
my lights to my ac/heater knobs and my transmission gauges on my shifter knob is not able to turn on. is there any fuse i can check? plz help.
T Pexx is offline   Reply With Quote
Old 07-25-2011, 07:34 AM   #2
PANEL1 in the under dash fuse panel
Old 07-27-2011, 01:48 AM   #3
T Pexx
i went out and replaced that fuse, and still no lights.
Old 07-27-2011, 07:34 AM   #4
Was the fuse actually blown? If not, make sure that your dimmer rheostat is not turned down all of the way.
Old 07-28-2011, 04:10 PM   #5
T Pexx
im pretty sure it was the fuse that was blown, and the dimmer is all the way up.
Old 07-28-2011, 04:56 PM   #6
Do other things light up when you turn the headlight switch on (like the hazard light switch, door lock switch {if you have power locks}) and does the headlight indicator turn on on the cluster?
Old 07-29-2011, 12:05 AM   #7
Revsson
Didn't you just install some foglights?
Did you run some wires up that way when installing the aftermarket switch?
Or is there anything else you have might have installed or done to the interior?
This might help track down the problem.
Tags
dash, interior, lights
Question about bi amping front components. YarisSedan In Car Entertainment + Electronics (audio / video / alarm) 6 08-28-2010 01:04 PM
Voltage regulator and Amperage question... cr.chango DIY / Maintenance / Service 13 11-24-2009 01:59 PM
ctrl-alt-delete question & free anti-virus question Shroomster Off-topic / Other Cars / Everything else Discussions 18 09-08-2009 04:57 AM
New Yaris + warranty Question hpvampiress New YARIS Purchase Forum 9 06-29-2009 07:39 PM
Amplifier Watt Question....noob question hasher22 In Car Entertainment + Electronics (audio / video / alarm) 4 09-27-2007 04:59 PM
