Old 10-12-2011, 08:18 PM   #4
^ If the spring rate on those isn't very high, you'll bottom out and have other problems. LOW springs should be STIFF springs.
lowering spring specs for Yaris botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 03-22-2017 09:47 AM
Hyperco 5.5" single pigtail rear spring test kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 06-15-2009 11:11 AM
proper wheel size/offset based on spring drop. marcus Performance Modifications 4 03-27-2009 11:33 AM
Lowest drop available with springs hatchbackkid82 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 12-14-2008 04:09 PM
Lowest Drop On Springs? Kaeon Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 08-20-2007 05:15 PM
