Old 01-19-2012, 08:45 PM   #11
Originally Posted by lcastrob View Post
omg !!!
today i came back from work, open everything... had my paper clip at hand and wasnt able to remove the pin...
im afraid of pulling too hard and leaving the connector but removing the wire...
any tips? i think i will have to ask a friend who has more experience on cars...
I prefer an Xacto knife blade to a paperclip (if I don't have a proper pin popper). The tab that you are lifting is only in about 1/4". lift the pin lock tab and insert the blade in as shown below. I like to angle the blade towards the metal of the pin to get the blade to go on the correct side of the plastic tab (it is very easy to go above it, which makes it impossible to pull the pin). Once the blade is in position, lift the tip away from the metal pin and you will hear a slight click from the plastic tab. At that point the pin will easily slide out the back of the connector.
Part #s for Fog Light install? Can anyone who works for Toyota confirm? IsLNdbOi Cosmetic Modifications (Exterior/Interior) 73 12-23-2010 05:15 PM
How to choose and install HID on FOG light charleschia1986 Cosmetic Modifications (Exterior/Interior) 18 12-20-2010 09:45 PM
Fog Light Install - HELP GrimlockGT Cosmetic Modifications (Exterior/Interior) 1 03-19-2010 04:58 PM
