play every day
Yes... you're the first.
play every day
All of the tooter manifold flanges are done now so I can start putting them on the manifolds...
![]() ![]() The manifolds are all in various stages of being cleaned. They all basically looked like that dark dirty one as they're 14 year old junkyard parts, many from crashed vehicles. They all have scratches and dings, but look pretty decent when they're all cleaned and blasted.
#3 | |
![]() ![]() Drives: Yaris '06 Join Date: Apr 2011
Manifold'mania
![]() Quote:
play every day
With the flanges done, the machining on the adaptors will be starting when I get these larger gaskets so that the adaptor design can be altered to fit them.
![]() This Corolla gasket is larger then the Yaris one and allows for a 51mm bore. I decided to make just one adaptor which will fit either a 1NZ FE or a 1ZZ FE throttle body. This will allow for an easy upgrade without needing to change anything else. |
![]() ![]() ![]() Drives: 2017 L 3-door Join Date: Mar 2011
wait... so is this your next venture? making a corolla xrs manifold fit the yaris? dooood!
#6 | |
play every day
![]() I still don't have a completed 1ZZ manifold yet, as the newely revised adaptors are still in the process of being machined. So far all I have is the running prototype on our daily driver. It's interesting that others have been doing the same manifold adapting idea. |
play every day
Finally... one completely finished manifold...
![]() The bead blasting put a nice low luster finish on it and made the welds look a lot better by making all the surfaces take on the same evenly blasted texture. I even blasted the adaptor so that it now has a matte finish similar to the throttlebody... ![]() ![]() ![]() ![]() Tooter #2 one now becomes the daily driver tooter because it had the worst dings in it. They're only cosmetic and are barely visible when looking low from the front, but it's still not fit for sale so I don't mind keeping it for our own use. I'm still waiting on the adaptors which should be ready any day now. Tooter #3 is ready for the welder, and tooter #1 is going to the blaster.
2ZR swap. DO IT! Ask how!
Damn, that's sexy! It's like car pr0n...
Looking good!
no show, no go :(
sexy!
play every day
I bought a Simota intake from Buddy Fan (Thanks, Buddy
) shortened and bead blasted it to match the manifold. And am waiting on a silicone adaptor to finish it off...![]() Test fitting it into the throttlebody... ![]()
That looks a lot better than before. The only concern is that the sensor is now a lot closer to the filter. Hopefully that won't cause a CEL.
#13 | |
play every day
The aluminium tube is 2.25 inches and the filter is 3 inches. There's plenty of room to move it out farther. For all the crazy experiments I've tried, so far I've never gotten a CEL light.
play every day
The silicone adaptor came today less than 36 hours after I had ordered it on ebay. That's speed of light shipping.
So now the intake is ready (plus one more clamp) to install on the throttle body tomorrow... ![]() ![]()
![]() ![]() Drives: 2008 Yaris HB MT Join Date: Jan 2009
I'm excited to see how the manifold performs with a 1zz throttle body. Good work on keeping this project going!
Also, is that a Simota intake tube for Yaris or for another car? The tube diameter looks larger than the 1nz throttle body. I am using a k&n intake right now and the throttle tube size is nearly identical to the 1nz throttle body diameter, so I knew in the future when I swap to a 1zz throttle body I was going to have to get an intake with a larger diameter tube. I remember reading something on here something saying that you couldn't go over a certain intake diameter because it would cause the MAF to throw a cel. |
#16 | ||||
play every day
![]() Quote:
![]() ...but is 2.25 inches at the MAF sensor which is the same as the Weapon R intake I've been using... ![]() The Weapon R flares out to 2.5" in front of the MAF sensor while the Simota remans at 2.25" but then flares out to 3" to fit the air filter. Quote:
play every day
Got the intake mounted and it fits fine...
![]() ![]() Next comes the test drive. (oooh, goody )edit: The engine runs great... and no CEL light. Last edited by tooter; 10-28-2012 at 05:32 PM. |
I see, thanks for the explanation. That's weird that the intake flares out right before meeting the throttle body. On the K&N it does not flare out so it doesn't require a reduced coupler.
| homemade intake manifold | ttr125fan09 | Performance Modifications | 1 | 02-17-2012 01:09 AM |
| Custom Intake Manifold + Direct Port Nitrous | blacksandiegovitz | Performance Modifications | 9 | 04-21-2010 07:05 PM |
| Turbo Manifold thread | Sabretooth | Forced Induction Forum | 78 | 05-22-2009 06:52 AM |
| turbo manifold build... | joey1320 | Forced Induction Forum | 4 | 06-30-2007 02:26 PM |
