Old 04-07-2013, 03:24 PM   #4
Originally Posted by dinop View Post
Thank you so much! I guess one of those cheesy remote starter kits will have to work. The tricky part is probably going to be fitting the remote guts into the key fob.
As for the keyless unit, where would I have to wire in the headlights? Would I do it at the stalk? Which pins would I need to connect to? If I end up getting a keyless entry/remote start kit, I don't want it to actually have control over the horn or the hazards or anything like that, I'd just want it to operate the headlights or the trunk.
Some of the aftermarket remotes are small enough for the guts to fit.
To turn on the headlights you just need to ground the light blue wire, next to the pink wire, on the headlight stalk connector.
Tags
delayed headlights, flip key, keyless, remote, trunk release
Help with replacing 2 button key remote hotnoodle DIY / Maintenance / Service 22 12-18-2016 05:26 AM
Transponder key programming teddy DIY / Maintenance / Service 6 04-28-2015 06:32 PM
Lost key (transponder and remote lock/unlock) shyeoh DIY / Maintenance / Service 4 07-11-2013 05:04 AM
Need remote key fraenx DIY / Maintenance / Service 1 06-26-2009 07:29 PM
