Old 05-31-2013, 07:09 PM   #1
toyofez
Drives: 2008 Toyota Yaris
CTScott,
That looks great. I think it's pretty much what I had in mind, but I was going to mount the bracket on top of the actuator, which would have been foolish :) Your solution looks pretty elegant.
Did you attempt to use the existing wiring harness and connect the actuator to that? If not, did you manage to route the actuator wires through the existing conduit between the door frame and the main body?
Thanks again for the photos!
toyofez is offline   Reply With Quote
Old 05-31-2013, 08:06 PM   #2
Originally Posted by toyofez View Post
CTScott,
I had to run a few wires through the door frame for the locks and windows. It is actually pretty easy, as you can feed them in behind the connector behind the kick plate, and then you can pop the rubber sleeve off on both ends to make it easy to get the wires through.
Compilation of Yaris How-tos/DIYs YarisBueller DIY / Maintenance / Service 39 04-28-2018 09:47 AM
Power Windows Question david_827 DIY / Maintenance / Service 4 08-27-2012 04:58 PM
power door lock problem bigdoglover DIY / Maintenance / Service 6 07-28-2012 02:08 PM
Help! MES power lock install question mr_thunder16 DIY / Maintenance / Service 5 11-13-2009 09:50 AM
