![]() ![]() Drives: 07 hatchback Join Date: May 2012
cracked CV joint help
So today I was changing my oil and noticed that there was something all over my drivers side wheel on the inner edge. I took the below picture.
I believe the CV boot is crocked or torn. What is the normal procedure for correcting this? A new boot or a new shaft? |
That does look like the boot has a crack or rip. People will sometimes just replace the boot (and there are split ones that install without removing the shaft, but they typically don't hold for long). With the work required to remove the shaft to replace the boot properly, your best best is to just replace the shaft assembly.
Blue struts, is the car lowered? Won't that change the angle and lead to rips then?
It is on eibach sportlines which does not drop the car very much at all. lowering the car will actually reduce the stress on the boots
New shaft typically 60 bucks at your local parts store. The time to change the boot only is not worth it and keep in mind if you change only the outer boot the inner boot rubber is dry and brittle and will tear likely soon after and you will end up having to take the axle out anyways to do the inner later on so might as well replace the entire unit.
Well I get the shaft and everything apart but did not notice the need for a slide hammer to get the shaft out before I torn into and it is the only car I have.
Any other way to get the drivers side shaft out of the transaxle? |
Can you post some pics
Not really. The inner joint is tight to a portion of the transaxle case to the front and part of the bottom. almost the rest of the bottom and the back side is blocked by the crossmember.
The joint has 3 notches that are machined in to facilitate its removal but because of the surrounding things it can not be driven out by using a hammer |
I had to remove both axels once on my 1997 Saturn 5 speed. They were tough to get out too. Bad thing is two days after the clutch job the trannny axel seals leaked! I didn't change those seals. Be careful..
Asshole
Drives: 2012 and 2013! Join Date: Aug 2012
A CV boot can be replace without removing the shaft from the transmission.
The trick is to cut the boot, remove the outer joint, pack the joint with new grease, slide the boot on, line up the outer joint to the shaft, and pop it on. Then tighten clamps. I've done thousands of boots in my previous career. The outer takes more stress along the folds due to steering. The inner will outlast the car. If the boot is still intact, the joint is still good. Boots are 8 bux at rockauto.com
Cheapest DD I could find!! |
I intend to replace the shaft and already have the shaft to do so. I also have to have this done by tomorrow night so I can get to work.
Asshole
Have a trasmission seal handy.
Well its done. Ended up talking to a mechanic that suggested using a crowbar to get the shaft popped out. after some work at it I got that to work. it was in there much harder than I would have guessed. Now its all back together and I got the ATF change I was thinking about doing before this happened done.
It was about an inch long crack at one of the point ribs |
| click after cv joint replaced? | bechdan | DIY / Maintenance / Service | 8 | 05-31-2013 05:16 PM |
| Cracked fog light lens! | rossman | DIY / Maintenance / Service | 2 | 10-05-2012 03:04 PM |
| Driveshaft + CV Joint | gordon_grech | Willing to Buy by private party | 1 | 01-12-2011 04:26 PM |
| Some dumb ass hit my car today and cracked the bumper.... | YarisSedan | Off-topic / Other Cars / Everything else Discussions | 12 | 06-10-2010 02:44 PM |
| Ball Joint on Bottom Arm | David Godfrey | DIY / Maintenance / Service | 1 | 04-18-2010 06:27 PM |
