Old 05-11-2013, 03:12 PM   #1
bechdan
Drives: yaris colour collection 1.0 vv
Unhappy click after cv joint replaced?
Ok bit of a strange one I think - 2003 1.0 yaris, outer cv needed changing, took it to a garage who tried 3 different brands of joint but none would fit, bit of a faff but eventually they said theyd have to replace the right side dive shaft which I agreed to as we needed the car back on the road. Anyway since then there has been a click noise every time the car changed speed significantly. I have recently replaced the engine mounts, wishbone, wheel bearing, brake etc on that side.
The click is loud and definately from the right side, it occurs when changing speed especially changing down a gear or changing from reverse to foreward.
I know most people would say - take it back to the garage, but I dont know if I trust them to do anything else.
Im confused as to how a new drive shaft could have a clicking cv joint if it is indeed the case. What do you think?
Thanks for any ideas.
bechdan is offline   Reply With Quote
Old 05-11-2013, 07:27 PM   #2
nookandcrannycar
I haven't had any problems with either the CV joints or boots on my Yaris (knock on wood). However, I had a GTI that I bought new and put over 194,000 miles on. One of the worst problems I had with that car was with the CV joints + boots (multiple replacements). Each time I heard the clicking sound you describe, it was the CV joints...and the sound disappeared after the (correctly completed I assume) repair.
Old 05-16-2013, 02:50 PM   #3
bechdan
update
I took it back to the garage, they said that if they found a fault they would replace it free of charge as the part was still under warranty.
They inspected the drive shaft and all other nearby components but could not locate anything out of place. They took it for a drive and did hear the same noise that I noted but they could not tell from the noise alone where it was coming from. Now I know its nothing serious and the car is still safe for my wife to drive, BUT it shouldnt be there and thats what bugs me.
Any other suggestions as to what the noise could be
off the top of my head could it be
suspension?
wishbone (replaced but ? faulty)
something else?
Old 05-16-2013, 02:58 PM   #4
Amdkt7
Returning to Toyota
Drives: 2013 L 3dr MT
Is it worse when turning, or perhaps go away when steering to one side and not the other? It does sound like an issue with the cv joint.
Amdkt7 is offline   Reply With Quote
Old 05-16-2013, 04:00 PM   #5
bechdan
update
no thats the confusing thing, it makes no noise on turning, its just when putting more power down or changing down a gear i.e. engine braking, anything that causes the car to jerk slightly foreward or backward.
Old 05-16-2013, 04:06 PM   #6
Amdkt7
Returning to Toyota
You need to have it jacked up and try turning the wheel by hand, forward and backward and see if you can hear it. The car should be in gear. If you can hear it that way you can track down where the sound is coming from. I have heard of other new cv joints making noises. It is also possible that they did not tighten up something properly.
Look for excessive play, compare it to the good side.
Old 05-31-2013, 02:30 PM   #7
bechdan
solved
the stupid garage id had the driveshaft replaced at had used the incorrect size hub nut, which meant that it would not tighten up fully, didnt need much more, just a couple of mm but that was enough. simple fix, new wheel nut and sorted.
Old 05-31-2013, 04:23 PM   #8
Amdkt7
Returning to Toyota
glad to hear it is fixed. Wonder where they got the wrong nut from?
Old 05-31-2013, 05:16 PM   #9
nookandcrannycar
While reading progressively down through each post (BEFORE getting to this post) my best hunch was that they did something wrong re the reapair and they just don't want to admit it. Glad to hear they made things right .
viper 5901 replaced battery, crank but no start yogi In Car Entertainment + Electronics (audio / video / alarm) 1 03-25-2013 08:15 PM
advice please - click when accelerating or decelerating bechdan DIY / Maintenance / Service 4 12-20-2012 02:48 PM
Replaced door panel fabric with perforated leather to match Clazzio seat covers CTScott Cosmetic Modifications (Exterior/Interior) 13 10-03-2011 11:43 PM
Driveshaft + CV Joint gordon_grech Willing to Buy by private party 1 01-12-2011 04:26 PM
Ball Joint on Bottom Arm David Godfrey DIY / Maintenance / Service 1 04-18-2010 06:27 PM
