Old 07-22-2013, 04:38 PM   #5
frog13
Tw200--excellent!
Drives: 2010 yaris..absolutely red.
Swidd......tightened the star until you could barely move the wheel?.....Now,are you saying after adjustment,you place the wheel back on and attempt to rotate or you are trying to rotate the unit with just the drum on? (much more difficult to rotate via the drum vs. the wheel being on.).If going that tight it would seem you would "burn-up" the drum and or the pads ASAP!!. Are you also adjusting the "nut" under the e-brake handle inside the car?;if so,is the plastic(s) a PIA to remove for this?. TIA
frog13 is offline   Reply With Quote
The Basics on Brake Upgrades kngrsll Performance Modifications 56 03-06-2024 08:50 AM
I dropped something down in my parking brake slot... Boonespeed Cosmetic Modifications (Exterior/Interior) 12 08-11-2009 09:31 PM
Parking Brake Shoe Adjustment bikegerm Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 07-14-2009 02:26 PM
DIY For radios that require attaching a wire to parking brake Slick DIY / Maintenance / Service 0 04-16-2009 08:14 PM
Parking Brake Adjustment Q's Lafiro DIY / Maintenance / Service 3 04-13-2009 08:19 PM
