![]() ![]() Drives: Yaris Sedan Join Date: Dec 2012
Definitely remove spark plugs when its cold. Hot plugs expands and tends to hold onto the cylinder head more tightly.
I changed mine out at about 125000km. It does require some force to break it loose but after that it screws out easily. With a standard size ratchet and extension, if you find it ridiculously stiff, maybe it is better bringing it to a mechanic. |
| Spark Plug Problem | TickleTimeTim | DIY / Maintenance / Service | 15 | 09-07-2013 10:18 AM |
| Spark plug Question please :) | lamadoo | DIY / Maintenance / Service | 8 | 04-08-2013 12:55 PM |
| How hard I should try to remove spark plug | mf4361 | DIY / Maintenance / Service | 24 | 03-30-2013 03:07 PM |
| Oil drain plug gasket question | schleppy | DIY / Maintenance / Service | 7 | 04-17-2009 06:35 AM |
| spark plug | 33lam | Performance Modifications | 25 | 12-23-2008 05:40 PM |
