Old 02-09-2014, 11:06 AM   #1
sociolog
Drives: yaris
Thank you I saw that this is tricky.
just for clarification, the control valve is on the right side of the alternator train (on the pictures it looks rusty)?
sociolog is offline   Reply With Quote
Old 02-09-2014, 08:47 PM   #2
alanwagen
Drives: 2015Yaris, Son's car, 10 Prius
control valve
Yes on the right, yours may not look like that. It may have cover.
alanwagen is offline   Reply With Quote
Old 02-10-2014, 06:18 AM   #3
sociolog
Drives: yaris
Thank you, just one more thing, when changing the belt I don't have to worry about first piston position like for example when changing timing belt?
i can just park the car and take off old belt and install new one without takng prior notice on the postition of the piston?
Old 02-10-2014, 08:35 AM   #4
alanwagen
nope and yes
The belt only spins the water pump and alternator. No timing involved. The bottom alternator bolt may be troublesome as it can be on real tight.
Old 02-10-2014, 12:33 PM   #5
sociolog
Drives: yaris
Thanks everyone for the reply and advices.
I will inform you upon replacement!
Thank you all very much for resolving my dilemmas!
Help with drive belt adjustment lh59 DIY / Maintenance / Service 9 08-01-2019 09:46 PM
Drive Belt jiamanuel Middle East 12 11-10-2011 09:30 AM
Need help replacing acessory drive belt!!! stevebo DIY / Maintenance / Service 13 04-07-2011 02:57 PM
service life of accessory drive belt? stevebo DIY / Maintenance / Service 5 05-10-2010 01:29 AM
Drive belt question toyo DIY / Maintenance / Service 4 02-22-2010 07:42 PM
