Old 04-14-2014, 06:32 PM   #1
chrisofknives
Drives: 2008 Yaris Hatchback
Help with drum brakes loosening after a week
I recently replaced the shoes on my 2008 liftback and the breaks were great for about a week after we changed the shoes. Gradually throughout that first week, the e brake, and brake pedal both loosened up, to the point of the ebrake not catching the back wheels at all, and I had to put a cinder block behind my back wheel in my sloped driveway.
We jacked it up again, and tightened up the star wheel, made sure the wheel only made one rotation after adjusting, and everything seemed fine...same issues after a week again. It gradually becomes more loose. Any ideas? Break fluid is good. No leaks. Not sure what to do...
chrisofknives is offline   Reply With Quote
Old 04-14-2014, 08:25 PM   #2
ex-x-fire
Did you mix up the LR & RR adjusters?
Old 04-14-2014, 08:26 PM   #3
chrisofknives
Did one side at a time.
Old 04-15-2014, 08:35 AM   #4
ex-x-fire
Make sure the adjusting lever arm is keeping the wheel from turning down. It only allows it to turn one way.
Old 04-15-2014, 03:38 PM   #5
chrisofknives
Ok thanks, I will take a look at it this weekend. Is it easy to screw that up when putting everything back together? I feel like we triple checked everything with our pictures that we took before doing the work.
Old 04-15-2014, 05:03 PM   #6
Yaristeve
Drives: 3-door hatch
IIRC correctly, most automatic adjusters spin the adjuster wheel when applying the brake in reverse. Perhaps try braking a number of times in reverse and see if that tightens the brakes up?
Old 04-15-2014, 05:39 PM   #7
chrisofknives
That was the first thing I tried. No dice.
Old 04-15-2014, 07:33 PM   #8
Yaristeve
I should of figured that; just looking for low hanging fruit.
Old 04-15-2014, 08:46 PM   #9
ex-x-fire
Is there a solid "click" when you turn the adjuster?
Old 04-15-2014, 08:49 PM   #10
chrisofknives
I have to look at it this weekend, if there isn't a click what could be wrong?
Old 04-16-2014, 10:21 PM   #11
ex-x-fire
Look at the picture I put up, the automatic adjusting lever is what clicks on the adjuster wheel. Look for problems there, is the arm bent, spring missing, installed wrong?
Old 04-30-2014, 07:38 PM   #12
chrisofknives
Ended up going to the dealer due to weather and my friend being out of town to use his garage. Turns out we must have put something back together just a little bit off. Adjuster arm was not hitting the star wheel right, and was allowing it to back off. Still came out on top after paying them $50. Cost me roughly $130 to do it myself versus the $250-$300 they wanted.
Question about drum brakes caineroad DIY / Maintenance / Service 4 12-14-2012 11:34 PM
when to replace rear drum brakes bankrobber DIY / Maintenance / Service 6 06-05-2010 10:38 PM
Rear Drum brakes bankrobber DIY / Maintenance / Service 0 04-18-2010 12:39 AM
Changing drum brakes to discs? eTiMaGo Performance Modifications 5 09-25-2006 05:17 PM
