Old 04-12-2007, 07:48 PM   #1
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Not to bring you guys down, but, this is a really bad idea. Max pressure is called that for a reason. You do know your tires heat up with highway speeds so even putting them at 44 means they are running far higher than that with sustained speed. Setting them at 60PSI means they could go over 70 with summer heat and fast driving. Blow-out time!
PetersRedYaris is offline
Old 04-12-2007, 07:56 PM   #2
BailOut
Steals terrorist's lunch
BailOut's Avatar
Back in the 1970's you would have been right, Peter. However, since that time consumer tires have been steel belted which prevents this from happening. The worst that could happen on just about any modern tire is some uneven and/or early tread wear.
I commute over a mountain every day in snow or sun at 60 PSI without issue. As I mentioned earlier a fellow hypermiler who does a lot of highway driving just hit 85,000 miles on his RE92s, which is literally impossible at 32 PSI. We are just 2 out of a pool of folks that have been running at 60 PSI for quite some time now not only without issue but with several tangible benefits.
- Brian
Share the Road
BailOut is offline
Why does Tirerack reccomend 185/50R15s for seeminlgy ALL of their 15" rims? St_G Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 03-16-2011 07:29 AM
Tire Pressure and Gas Economy KittenRD General Yaris / Vitz Discussion 11 01-25-2007 11:54 PM
Tire Pressure slvryaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 11-05-2006 01:37 PM
stock tire pressure... argylesocks Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 09-16-2006 01:28 AM
The Tire inflation debate... Tankota General Yaris / Vitz Discussion 20 06-01-2006 08:09 PM
