Old 04-12-2007, 09:41 PM   #1
BailOut
Steals terrorist's lunch
BailOut's Avatar
... but other things like braking and cornering will be adversely affected, and should you have an accident through a blow-out, and it is found all your other tires are over-inflated, you will have a hell of a fight with your insurers...
Actually, the inverse is true about braking and cornering since there is no tire sag to deal with. The higher pressure offers much better handling, not worse. Try it for yourself.
You have a valid point about insurance companies because they are generally uneducated about such matters. I do not bow to a lack of education... I educate the uneducated.
- Brian
Share the Road
BailOut is offline
Old 04-12-2007, 10:08 PM   #2
SailDesign
Drives: .
Up to a point, higher pressure helps. I'm at 43psi right now on 205/45-16s, and it works well even in rain. But, too high a pressure reduces the contact patch with no increase in coefficient of friction, since the tyre/tire becomes more brittle at a certain load level and fractures (at an almost microscopic level) rather than grips. The trick is in finding the "sweet spot" for your tyres and car. There was a good article on tyre physics in... someone help me out, here - one of the Sports Compact/GrassRoots Motorsport/Modified mags recently. Well worth reading.
"Inverse"? Is that the same as "opposite", but for edjimacated folks?
SailDesign is offline
Why does Tirerack reccomend 185/50R15s for seeminlgy ALL of their 15" rims? St_G Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 03-16-2011 07:29 AM
Tire Pressure and Gas Economy KittenRD General Yaris / Vitz Discussion 11 01-25-2007 11:54 PM
Tire Pressure slvryaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 11-05-2006 01:37 PM
stock tire pressure... argylesocks Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 09-16-2006 01:28 AM
The Tire inflation debate... Tankota General Yaris / Vitz Discussion 20 06-01-2006 08:09 PM
