Old 11-03-2016, 10:10 AM   #1
sorka
Drives: 2007 Yaris Sedan
Slow idle after clutch replacement.....
After warming up, idling around 480 which is giving the engine mounts a work out. Short term fuel trend showing -5% or so when I rev between 1000 and 2000 RPMs. This is my moms car so I don't know what it was doing long term but it wasn't idling this slow when I got it last week to bring it home. I suppose it's possible that resetting the long term fuel trend when I pulled the battery is exposing an existing issue but I don't think that's it.
The only thing engine wise I took off when I remove the transmission was the air box and what I'm guessing is the PCV return hose upstream of the throttle body. All that's back together. The bands for the airbox are correctly tightened and there's no obvious hiss from any sort of leak.
I'm stumped.
sorka is offline   Reply With Quote
Clutch Maintenance fnkngrv DIY / Maintenance / Service 12 03-03-2017 10:42 AM
Aftermarket Clutch Q's tmontague Performance Modifications 5 03-05-2016 04:33 PM
Clutch Kit Replacement - Which brand to go with? fourbangingfun General Yaris / Vitz Discussion 5 07-04-2015 10:58 AM
Clutch Replacement BobTheYaris DIY / Maintenance / Service 3 03-25-2014 08:17 AM
'07 Yaris Clutch replacement dinop DIY / Maintenance / Service 12 04-22-2013 04:47 AM
