you are in phoenix, and it is hot. your pressure IS higher because of your environment. if you ran at 28-30psi they will run more even, but overall they may wear faster. you will have better traction and breaking. it depends on what your end goal is....
buy a tire with a UTQG of 500(+) A or AA, A and run at 30psi. you will be happy on both sides of wear and longevity.... (IMO) |
| Uneven wear after rear spacers | Focus_Sh1ft | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 05-16-2013 01:17 PM |
| NITROGEN GAS TIRE FILL: WORTH IT? | EjDaPogi | Middle East | 15 | 03-20-2011 02:06 AM |
| Tire Wear Analysis | Loren | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 13 | 06-13-2009 09:28 AM |
| Does the TRD rear sway bar promote tire wear? | detroiter | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 03-29-2009 10:29 AM |
| The Tire inflation debate... | Tankota | General Yaris / Vitz Discussion | 20 | 06-01-2006 07:09 PM |
