Old 10-29-2018, 11:21 AM   #11
atomic_hoji
Drives: 2018 Yaris SE 5MT
1. looks like fuel - trace it toward the engine, should run along the side of the cyl. head and up to the fuel rail.
2. purge solenoid - should have an electrical connector just above (power to sol'd) and a tube will run to the firewall to the NON-fuel supply line from the fuel tank; can follow the pair of hard lines under the car rearward. This vents the fuel canister I believe.
3. no idea? I don't have a rear line like that, unless the Corolla(sedan) has heater lines different than the I'm. Maybe run back to the block and see where it comes from?
4. valve cover vent - as Trevor noted does to a nipple on the intake tube a few inches before your throttle body.
Sorry, on phone, so short and probably type-o filled.. lol
-- Adam
atomic_hoji is offline   Reply With Quote
T Montague's 2zr swap - '08 m/t sedan some extra info tmontague Performance Modifications 285 04-20-2021 11:56 AM
How frequently does the automatic transmission fluid need to be changed? Hamster DIY / Maintenance / Service 40 12-15-2018 09:07 PM
2zr swap and e-test in Ontario tmontague Performance Modifications 7 12-23-2016 09:12 AM
Problem help MickZEL DIY / Maintenance / Service 38 08-01-2011 02:52 PM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
