Old 10-29-2018, 05:40 AM   #11
tmontague
tmontague's Avatar
I'll have to look at my engine to see where those red capped tube openings go. Iirc number 4 goes directly to a port on the intake tube before the throttle body.
In regards to the a/c, I bent the lower part near the compressor. I dont remember which was but enough where the rubber part was no longer rubbing against anything and there was less strain on it. I put it in a vice to bend
T Montague's 2zr swap - '08 m/t sedan some extra info tmontague Performance Modifications 285 04-20-2021 11:56 AM
How frequently does the automatic transmission fluid need to be changed? Hamster DIY / Maintenance / Service 40 12-15-2018 09:07 PM
2zr swap and e-test in Ontario tmontague Performance Modifications 7 12-23-2016 09:12 AM
Problem help MickZEL DIY / Maintenance / Service 38 08-01-2011 02:52 PM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
