Technically a non micro fuse tap works (that's what I used in my under dash wiring) however if you use it in the fuse box under the hood it will not allow you to close the lid all the way. It will still work temporarily however and it will give you an idea if you wired everything properly
And yes the pins can be inserted with only the main retaining clip opened, its removing them where you have to deal with the secondary retaining system
| T Montague's 2zr swap - '08 m/t sedan some extra info | tmontague | Performance Modifications | 285 | 04-20-2021 11:56 AM |
| How frequently does the automatic transmission fluid need to be changed? | Hamster | DIY / Maintenance / Service | 40 | 12-15-2018 09:07 PM |
| 2zr swap and e-test in Ontario | tmontague | Performance Modifications | 7 | 12-23-2016 09:12 AM |
| Problem help | MickZEL | DIY / Maintenance / Service | 38 | 08-01-2011 02:52 PM |
| Want opinions automatic vs. manual transmission | anik | New YARIS Purchase Forum | 84 | 07-10-2007 04:25 PM |
