Old 10-28-2018, 01:28 PM   #11
tmontague
tmontague's Avatar
You need to pop up the retaining clip which you did and then you need to take a small needle (I used a sewing needle) and push down on the pin you want out.
I cannot remember which way or really explain it well but I practised for weeks on mine before I actually did the swap.
Once you get it you'll understand. But bottom line is you need to use a small pin to actually push the prong down that also holds the pin in. So there are 2 things that hold the pin in, not just the main retaining clip on the connector
T Montague's 2zr swap - '08 m/t sedan some extra info tmontague Performance Modifications 285 04-20-2021 11:56 AM
How frequently does the automatic transmission fluid need to be changed? Hamster DIY / Maintenance / Service 40 12-15-2018 09:07 PM
2zr swap and e-test in Ontario tmontague Performance Modifications 7 12-23-2016 09:12 AM
Problem help MickZEL DIY / Maintenance / Service 38 08-01-2011 02:52 PM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
