Old 04-29-2019, 06:23 AM   #11
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Originally Posted by tmontague View Post
Pro tip: transmission line that enters the trans high up tends to be the return line. The line that attaches low on the trans housing tends to be the feed line.
I went with that when flushing the trans fluid on my wife's Vibe and saved me quite a mess.
This confirms your explanation. I found this in my U340E Transmission service manual. Now, I am assuming "Inlet" and "Outlet" refer to the direction of fluid flow relative to the engine and not the cooler.
Hoping to source some of these locally. I figure there's no reason I can't just put these through the upper loops of the trans cooler to support the top. I'll figure something else to secure the bottom.
3rd gen 2zr swap with 6 speed stidnam Performance Modifications 97 06-29-2021 04:59 AM
Hyundai Turbo Veloster 150kw *MAD DOG* Off-topic / Other Cars / Everything else Discussions 6 01-09-2012 11:35 PM
ZPI Turbo for one lucky Yaris owner..... ZPIracing Forced Induction Forum 27 04-26-2007 10:36 PM
