![]() Drives: 09 yaris hb Join Date: May 2014
New 2zrfe swap.
Due to this pandemic, it looks like I'm going to have time this summer to try this swap.
This is a bigger job than I've ever attempted so hopefully I don't screw stuff up to badly. The car is a 09 mt hatch. Parts gathered so far: Xd mt ecu Xd mt harness ( relatively poor shape) Xd auto harness( in case I need to salvage a broken connector) MWR lightweight flywheel and bolt set Cheap knockoff DC intake with a good KN filter Xd clutch kit (Luk) There are lots of Corolla engines near me in the 600 to 800 range so I need to decide on one and determine what is missing or needs replacement. I read thru the other swap threads on here and the wiring part is still a little confusing. I figure it is probably something that will make sense once I get into it. I'll do my best to post some pictures and any advice is appreciated. Last edited by Basmii; 05-10-2020 at 04:43 PM. |
2ZR swap. DO IT! Ask how!
Awesome! Glad to see another cultist--er, conversion started. Looking forward to seeing your build.
Welcome to YW! |
Appreciate it man. I'm sure I'll have a million questions for you and the others who have done it.
Gen 3 > Gen 2
Drives: NCP131, F-150, Focus ZTS Join Date: Jul 2019
Makes me want to start gathering parts to swap my '14, xDs are a chore to find in yards, especially manual ones.
2014 NCP131 5 Speed 2007 F150 4.2L 5 Speed 2002 Ford Focus ZTS 5 speed 2013 Rav4 LE AWD Autotragic - Wife's
Indeed. I found an MT xD at a dealership with lots of body damage for about $3500 and considered buying it just to pull it apart and make a kit from it. I've found one MT locally at a you-pick and it was in awful shape--Great Stuff foam in the already-deployed steering wheel airbag, kludge fixes everywhere.
There's a lot of info to digest but reading through the existing build threads will probably answer a lot of them. There shouldn't be very many--if any--unknown unknowns at this point but it's possible. I'll be happy to help either way. =)
#7 | |
Gen 3 > Gen 2
The Corolla and Matrix have the ECU on the driver's side, next to the battery and fuse box, the Yaris is on the passenger side. I'm pretty sure that Project Vios has a Corolla harness, but it had to be reworked pretty significantly to move the connector to the other side of the engine. I don't recall if there are pin incompatibilities on that harness but it's possible some wires have to be relocated in the connectors. The xD is direct fit, no faffing about. =)
Started working on my MT harness this morning. It appears that there are three kind of shady connections near one of the fuse box plugs. Beyond that it seems in ok shape.
Anybody got tips for depinning this thing? I tried just pressing on the little plastic tab inside with no luck. |
![]() ![]() ![]() Drives: Starlet Join Date: Nov 2017
I can't see the bottom of the connector, but do they have a secondary locking bar on the other side that needs to be pulled up first?
Most of these plugs just need the primary tab lifted up from inside before pulling the pin out. But many of them also have that secondary locking bar as well that needs to be disengaged first |
Yay! This is great! I've been waiting for another 2ZR swap to happen. I was apprehensive and frankly a little lost (nay, a lot lost) when I started, but the amazing guys here held my hand through the process. I hadn't done much more than brakes, oil changes and a few bolt on parts before my swap. Congrats!
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 05-18-2020 at 08:40 AM. |
No secondary tab as best as I can tell. I have a buddy that is going to bring over a set of specialized pin tools that he thinks will work. If not I will just cut the existing repairs and resolder/shrink wrap them on the connector.
3 Yaris and counting..
http://imgur.com/a/2ESv8Ax
http://imgur.com/a/lfEUG4m http://imgur.com/a/3UCr9Ba The bottom link is what the fuse box plug will look like when you are ready to pry up the tab inside the connector that holds the pin in. If the 'bar' on the side of the connector is flush with the connector the pins will not come out as they are locked un place. Use a pry tool (small screwdriver or a sturdy pick) to lift the lock as pictured in the third link. Hope that helps
I picked up my motor this week. 53,000miles out of an A/t Corolla for $600. It's missing the exhaust manifold which may be the universe telling me to buy an expensive header.
#15 | |
Looks like a beauty of an engine! Hopefully the internals are clean as well. If you've got some spare cash for the swap and want to be the first to try it, monkeywrenchracing.com has a long tube header for the 2ZR Corolla. No idea if it will clear the firewall and fit into the Yaris tunnel, but someone needs to find out. ;) |
#16 | |
Aah, I see that it's already been damaged/spliced. Ideally you would replace the whole wire to maintain the integrity of the insulation but that's not really practical in most cases. Heatshrink butt splices are fine here, just make sure you have a proper tool for both crimping and heating.
| Yaris Motor Swap Thread *Read before posting swap threads* | Sabretooth | Performance Modifications | 219 | 06-10-2025 02:58 PM |
| 3rd gen 2zr swap with 6 speed | stidnam | Performance Modifications | 97 | 06-29-2021 04:59 AM |
| THE 2ZRFE engine swap thread - Just the facts | brushforhire | Performance Modifications | 40 | 12-24-2019 11:08 PM |
| 2zrfe Engine swap - $500 picked up | brushforhire | Items for Sale by private party | 0 | 03-17-2017 10:21 AM |
| My 2zrfe swap | brushforhire | Performance Modifications | 131 | 06-08-2016 09:43 PM |
