Old 07-19-2020, 11:49 PM   #16
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Originally Posted by Desircustoms View Post
For the 1st time I opened the gauges on the aem software and saw that the rpm was not accurate, so I calibrated the rpm and TPS and it seems to have fixed the hesitation on full throttle, it did hiccup once after the calibration but not as much as before.
I think its the maf readings, will try to do a maf map, but I only have "stock engine" live data from techstream and it doesn't show voltage of the maf, only gm/sec.
You should be able to see MAF in and out voltages in the FIC software. Did you clamp your MAF at 5V? I really think there are much better alternatives to the F/IC. I'm still considering an ECUMaster ECU. Have to do more research first though.
my echo turbo build log ipwnr Forced Induction Forum 26 07-14-2015 10:09 AM
Turbo build - stage 1:D abstractmethod Forced Induction Forum 21 03-13-2014 08:04 AM
Want to build costom turbo kit. Need advice from boosted guys! pimp my yaris Forced Induction Forum 639 09-28-2013 11:26 AM
Hyundai Turbo Veloster 150kw *MAD DOG* Off-topic / Other Cars / Everything else Discussions 6 01-09-2012 11:35 PM
