Old 02-05-2023, 02:07 PM   #1
Steve0
Drives: Toyota Yaris 2006
Exclamation ABS Power Supply to rear right wheel
Hi All,
I have an issue with my 2006 Yaris ABS and Brake Light Illuminated !
Error code CO210 Right Speed Sensor rh Circuit.
After exploration found no voltage at the connector from the car side to the harness to the ABS sensor. On the left shows around 10v DC.
Anybody know where the next connections are along towards the engine bay so I can trace to the initial power source and check for an open circuit ?
I've checked all fuses relevant and seem fine.
Any help would be greatly appreciated. Cheers
Steve0 is offline   Reply With Quote
abs, error dtc c0210, power supply
2010 2 dr yaris rear wheel bearing replacement romram DIY / Maintenance / Service 5 12-30-2020 09:03 PM
passenger side rear wheel sitting higher than the rest... b20vteg Third Gen Yaris General Discussion 6 12-21-2013 11:54 PM
2012 Camry Kal-El Off-topic / Other Cars / Everything else Discussions 26 10-02-2011 09:20 PM
