Old 01-24-2009, 04:34 PM   #19
auxmike
auxmike's Avatar
Originally Posted by PetersRedYaris View Post
Go to Sparks Toyota-
http://trdsparks.com/index.php
$53 for the OEM pump and gasket...
Check again.
It appears to be $79?
http://www.trademotion.com/partlocat...07&catalogid=1
Old 01-24-2009, 05:57 PM   #20
CB900F2
Drives: 08 Sedan
A belt tension gauge should be used to check the tension on the belt and to insure it is with in spec...
Originally Posted by ztrack157 View Post
I have NST as well. And in the last 2,000 miles I heard a noise I knew shouldn't be coming from the engine bay. It was the water pump. I don't know what is considered to tight I can still wiggle the belt. And I had thought it was to tight so i loosened it slightly and then spun the belt so it wasn't to tight after installation.
CB900F2 is offline   Reply With Quote
Old 01-25-2009, 02:34 AM   #21
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
yeah well easier than going out and buying a belt tensioner gauge is to just 'eyeball' the deflection.....
where the belt is stretched between the farthest pulleys, push down on it it shouldn't move maybe 1/2" to 3/4" down ---any more and add tension......
Old 01-25-2009, 02:50 AM   #22
ztrack157
Vroom Vroom Beep Beep
ztrack157's Avatar
Drives: Powered Roller Skate
Send a message via AIM to ztrack157 Send a message via MSN to ztrack157 Send a message via Yahoo to ztrack157
My pump was $68. There are about $55 otherwise from Kragen/Schucks?checker or whatever the hell they are in your area. Mine is OEM replacement. The others are Cardone.
Ever blown out an R-200 diff god know's I have
ztrack157 is offline   Reply With Quote
Old 01-25-2009, 03:01 PM   #23
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Originally Posted by auxmike View Post
Haha, Sucks to be you. The Xb water pump is only $53.87, I assumed them to be the same. I see no reason why they would be different, same motor and the pulley must be transfered...
http://www.trademotion.com/partlocat...05&catalogid=1
Old 01-18-2010, 07:18 PM   #24
CB900F2
Drives: 08 Sedan
Peter.. Did you ever change out your water pump??...
On Scionlife I have read about quite a few water pumps failing early. Same motor, same pump? Probably just a freak thing...
Edit- Well what do you know, 59,000 miles and my pump has some crust below the weep hole. These water pump failures seem to getting more and more common.
Old 01-18-2010, 08:19 PM   #25
YarisSedan
Drives: 08 Yaris Sedan
My water pump has gone out twice already i have 23k miles.
Old 02-04-2010, 02:20 PM   #26
GeneralDon7
Drives: Yaris Sedan
The dealer actually notified me that mine was leaking when I went in to do that Seat belt tensioner recall. They covered it then (40,000 mi), not sure if i would be now(71000 mi).
GeneralDon7 is offline   Reply With Quote
Old 02-04-2010, 03:27 PM   #27
127.0.0.1
'easier' is not necessarily correct. same with bolt torque.
if you do not have the correct tools,
you have no business in the engine compartment
(not -you-, I mean anyone)
anyhow, water pumps do fail and they are easy to replace. they should last >180,000 though
Old 02-04-2010, 04:13 PM   #28
Aothachos
Drives: 2008 Yaris Sedan
Send a message via AIM to Aothachos Send a message via Yahoo to Aothachos
Someone told me if you can turn your belt to the side with one finger, its tight enough, so thats what I have been doing, I might have to tighten it a littttttle bit just a little because it has been squeaking bad on cold starts only when it warms up its find.
and my water pump hasn't had any problems yet, i have 50,000 miles on my car with the whole nst pulley setup (10 % underdrive crank, wp, alt.)
Aothachos is offline   Reply With Quote
Old 02-04-2010, 07:12 PM   #29
bankrobber
Drives: 2007 Yaris Hatchback
I have 81,000 miles and everything is stock on engine. Not had a problem with water pump yet.
Old 02-04-2010, 10:15 PM   #30
fmicle
fmicle's Avatar
Drives: 2007 Yaris LB
It's exactly the same price as the Yaris one Your link:
Water pump, xb 04-06 $92.34 $73.87
Unless the 7 is displayed as 5 on some computers
5% Tint Rear | Micro Image LED Ignition Light Kit
Old 02-05-2010, 02:55 PM   #31
TheSilkySmooth
TheSilkySmooth's Avatar
Hey, is there a water pump lube from toyota or coolant conditioner to add at say 30k miles? - I hear all these problems are from the long life coolant. My Rav4 WP puked at 50k miles too ;(
Old 03-15-2010, 02:32 PM   #32
kou
Drives: 08 lb
please sticky to DIY section.Thanks.
Old 04-24-2010, 02:51 AM   #33
OtownYaris
OtownYaris's Avatar
Drives: Meteorite Yaris Liftback
Send a message via AIM to OtownYaris Send a message via Yahoo to OtownYaris
I just had my water pump replaced today @ 33K miles. The car turns 3 years old this month. Kind of disappointing. The underside of my hood looked exactly as shown in the picture.
OtownYaris is offline   Reply With Quote
Old 06-11-2010, 12:57 AM   #34
Lucas13
Drives: 07 Yaris LB
Mine went out at 55k and other stuff is going out too such as my transmission leaking too!
Lucas13 is offline   Reply With Quote
Old 06-11-2010, 01:00 PM   #35
bronsin
bronsin's Avatar
I think a Yaris is good but it doesnt appear to enjoy the stellar reliability of its forerunner the ECHO. Never heard of this wp issue with the ECHO and its even the same engine. Some have said the L life coolant is to blame. Does anyone know if any other Toyotas having wp issues? Wife has a Camry with 60k and so far so good.
Old 12-05-2010, 07:49 AM   #36
auxmike
auxmike's Avatar
Mom's 2006 Corolla pump lasted 16k.
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
DIY: Strut Tower Brace Bar redyaris DIY / Maintenance / Service 18 03-16-2014 06:52 PM
DIY: Yaris LB Halo Led Projector Headlights goku87 DIY / Maintenance / Service 37 11-15-2013 06:23 AM
DIY Requests. TinyGiant DIY / Maintenance / Service 13 10-29-2008 10:39 AM
