Old 06-15-2010, 10:09 PM   #19
Originally Posted by jpmck03 View Post
When I got my stalk out of the bag, the red thing was in there separate from the stalk.
Anyone have a clue how it's supposed to go back on, and if it's just a temporary thing used to aid in putting on the stalk?
Should be putting this all together this weekend, so any help before I go from the shallow end to the deep end of the "Yaris mods pool" would be great!
The service manual just shows using a pair of pliers to keep the band clamp open while slipping the switch over the column. I'd use a small pair of needle nose vice-grips to make it easier.
Old 06-15-2010, 10:31 PM   #20
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
Hmm, this seems like something that I'd need to see a picture of to see if where I think it goes is right. I'm assuming that I'll see it on the factory switch when I pull everything off this weekend...
CTScott, do you have a copy of the service manual I could see or is it on paper?
Old 06-15-2010, 10:47 PM   #21
The entire service manual is posted in a sticky in the DIY section, but this image shows it:
Old 06-16-2010, 05:45 PM   #22
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
I forgot that those service manuals were there...
...but, I've got it!
The metal hoop is simply a clamp that, once you remove the red part, holds the stalk onto the steering column.
The only thing I'm wondering is, can I tape the clock-spring in order to keep everything in the same position once I put it back on. I'm thinking either this is one clever idea... or really dumb. (Yeah, that's nothing to do with the light stalk...)
Old 06-16-2010, 10:41 PM   #23
Tape is definitely a good idea. Below is a link to a video I just put together to make things easier for you. A picture may be worth a thousand words, but a video is worth millions...
http://www.youtube.com/watch?v=LgWSzVeILhc
Old 06-17-2010, 05:59 AM   #24
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
CTScott, you are the man!
Old 06-19-2010, 04:51 PM   #25
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
Thumbs up
Done and done!
DIY - Liftback Intermittent Wipers via Stalk Replacement (v2.0) CTScott DIY / Maintenance / Service 142 06-25-2024 01:47 AM
DIY Variable Speed wiper stalk install DanQ DIY / Maintenance / Service 27 08-03-2017 07:22 PM
DIY Projector/HID (sedan) Brian DIY / Maintenance / Service 145 02-05-2012 04:13 AM
Silverstar Ultra 9003/HB2 vs OEM headlight bulb comparison CTScott DIY / Maintenance / Service 54 02-14-2011 08:58 AM
How To Smoked Sedan Headlight -DIY zulhizainL902S DIY / Maintenance / Service 26 01-14-2011 02:12 AM
