#19 |
The alternator should be putting out at least 13.5 volts, even with the AC fan on. I would definitely say that you have a bad one.
#20 |
![]() ![]() ![]() Drives: 2007 Yaris HB 5spd Join Date: Jan 2015
Saw your thread on resetting airbag. Haven't gotten the chance to reset yet.
#21 |
Why isn't my fan turning on?
#22 |
It could be that you have another fuse out, or it could just be that the voltage is two low to spin it up.
#23 |
The fuse panel cover inside the car under steering wheel has diagram of two acc 7.5 a fuses along with 30A power fuse and one other. Their all intact. The cover says BM in that section. They mean the ones in front by wiring harnesses? Wondering what that AMT pin is still inside fuse box in engine compartment. Any ideas?
#24 | |
The AC system has one 7.5A fuse for the AC ECU, a 40A HTR fuse for driving the fan and a 40A HTR1 and a 30A HTR2 fuse for the PTC heater. None of those would make your alternator output as little as it is.
#25 |
Sorry man. Just read back a little. Alternator is putting out normal voltage when engaged. Just when I switch dial for blower it drops to around 12.5V and blower doesnt blow
#26 |
That is still way too low under load.
#27 |
http://www.yarisworld.com/forums/showthread.php?t=9473 Its not a relay socket. Its an open with pin. There is a pic of it here on this thread. Its the slot on right at end of mini's.
#28 | |
That's an unused un-switched fuse socket with an input pin that is powered directly from the battery (via the 60A MAIN fuse) and with no output pin (hence only one pin).
#29 |
Thats the one I accidentally hit with ground.
#30 |
Right - That's what popped the original fusible link that was blown.
I would triple check and just in case replace the ALT-S 7.5A fuse and the 7.5A MET fuse in the under-dash fuse panel. After checking those, measure the voltage on the small pink wire connected to the alternator. If you see 0 volts on that wire, then you definitely damaged the internals of the alternator.
#31 |
Will do. Your knowledge of these cars is pretty impressive. I want to thank you for all the help and guidance your giving me. Really appreciate it.
#32 |
That did it. What does that fuses tie into?
#33 |
Alt-S feeds the voltage regulator on the alternator a reference voltage.
MET feeds the charging indicator on the instrument cluster.
| DIY - Exterior lights on when doors are remotely unlocked | CTScott | DIY / Maintenance / Service | 21 | 07-31-2025 06:30 PM |
| radio wire colors & alarm wire color reference guide | battleversiontc | In Car Entertainment + Electronics (audio / video / alarm) | 43 | 06-06-2023 02:12 PM |
| Wires Inside the Yaris & What They Do | The Architect | DIY / Maintenance / Service | 149 | 10-18-2022 03:32 AM |
| Auxiliary Input Help | Oned | In Car Entertainment + Electronics (audio / video / alarm) | 88 | 02-27-2016 01:32 AM |
| Viper Alarm Install | gwasabi | In Car Entertainment + Electronics (audio / video / alarm) | 28 | 08-11-2010 02:57 PM |
