Old 03-09-2015, 11:04 PM   #1
Innovative 1
Drives: 2007 Yaris HB 5spd
accidentally hit the amt pin with ground
Was trying to aim headlights and accidently hit amt pin in fuse box inside engine compartment. Shut car off, headlights interior lights etc dont work now. And car wont start. Help me someone please?!
Innovative 1 is offline   Reply With Quote
Old 03-09-2015, 11:26 PM   #2
I am not sure what you mean by "amt pin", but you likely popped one of the large fusible links on the positive battery terminal.
Old 03-09-2015, 11:37 PM   #3
Innovative 1
I checked them and still intact. I have no hazards,turn signals interior lights gage clusters and wont start.
Old 03-09-2015, 11:39 PM   #4
Innovative 1
Check 30a power fuse.good. checked all mini's under steering column.good checked all fuses in engine compartment.good.
Old 03-09-2015, 11:40 PM   #5
Innovative 1
Have no radio either.
Old 03-09-2015, 11:40 PM   #6
Innovative 1
Or horn.
Old 03-09-2015, 11:46 PM   #7
Innovative 1
That exactly what I did. Temporary fix to get down the road?
Old 03-09-2015, 11:46 PM   #8
For the things that are out, it is almost definitely the 60A MAIN fuse on the positive battery terminal.
Old 03-09-2015, 11:48 PM   #9
Temporary fix is tough. You could pop the clear cover over the link and solder it back together as a very temporary fix.
Old 03-10-2015, 12:30 AM   #10
Innovative 1
Your the man Scott. I over looked the fuseable link. Blown.
Old 03-12-2015, 11:26 PM   #11
Innovative 1
So I got the new fuseable link today. Put it in started the car. Got no blower fan airbag light on. Checked battery voltage while running. Volts dropping and alternator isn't kicking in. Checked 7.5 alt-s fuse. Fuse good. Checked 40 htr block fuse. Looks good. The amt slot is open with one pin in it. That the one I accidentally hit with ground when I was trying to aim my new headlights. Did I fry alternator? Seems to be the issue but want to make sure.
Old 03-13-2015, 06:18 AM   #12
The things that are not working run off the other fusible link on the block (120A ALT). Take a peek to see if that guy popped when you replaced the block.
Old 03-13-2015, 09:22 AM   #13
Innovative 1
Thats the one beside the 60A main right? That one was intact. Took alternator out and having it tested today to see if I fried her. Is the voltage regulator integrated in alternator itself or seperate from it?
Old 03-13-2015, 09:28 AM   #14
Innovative 1
Ive got power down to alternator via cable. 120 alt fusable link not popped. Alternator just not kicking on. Rechecked all fuses. None blown.
Old 03-13-2015, 11:29 AM   #15
Innovative 1
Alternator tested good.
Old 03-13-2015, 05:37 PM   #16
Innovative 1
Ok. So I put alternator back in. Checked the voltage with out blower fan running and it charges. As soon as I turn knob to kick on blower fan voltage dropa which is normal. But fan doesn't work and alternator isn't kicking in to compensate for draw. Both fuses and fusable link good. All other accessories work normal. Just no blower motor and draw.
Old 03-13-2015, 05:59 PM   #17
How far does the voltage drop with the fan on?
Old 03-13-2015, 09:23 PM   #18
Innovative 1
Not too far. 12.5 V range initially the over about 10 mins at idle voltage drops down to where it kills car. Blower doesn't blow air when switched on. Another thing I noticed is the battery light flickers a couple times upon start up the shuts off. Airbag light comes on at times upon start up and usually stays on when it does.
DIY - Exterior lights on when doors are remotely unlocked CTScott DIY / Maintenance / Service 21 07-31-2025 06:30 PM
radio wire colors & alarm wire color reference guide battleversiontc In Car Entertainment + Electronics (audio / video / alarm) 43 06-06-2023 02:12 PM
Wires Inside the Yaris & What They Do The Architect DIY / Maintenance / Service 149 10-18-2022 03:32 AM
Auxiliary Input Help Oned In Car Entertainment + Electronics (audio / video / alarm) 88 02-27-2016 01:32 AM
Viper Alarm Install gwasabi In Car Entertainment + Electronics (audio / video / alarm) 28 08-11-2010 02:57 PM
