Old 12-09-2015, 10:25 PM   #19
Fluxtasy
feed my pet
Fluxtasy's Avatar
Drives: Yaris Sedan '10
And the connector is the same as on the standard 1nz harness correct?
I think the connector should be the same.
Yeah Okada are costly but there are other options. T.M. Works specialize in ignition tuning products. I'm using their basic harness:
http://tmworks-web.jp/products/dph_eng.htm
or you can go further with 16v: http://tmworks-web.jp/products/alpha_eng.htm
and even a few more stages of upgrades.
Their full stage upgrades might be even more costly vs Okada and the debate is still going on which is better.
Fluxtasy is offline   Reply With Quote
Old 12-09-2015, 10:33 PM   #20
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
The Okada doesn't really net much for the investment really. On a ka20 for example with a GT2835 @ 8PSI only gains 7whp and 17tq. Of course as the boost increases you will see a larger gain but it isn't exponentially linked.
I am very intrigued by the idea of using the higher end Vitz coil packs. Wish that there was a spec sheet comparison between them and the standard coil packs. I am sure when we Dyno my newest setup we will see if it would be of any benefit to make the upgrade.
Sent from my XT1575 using Tapatalk
Old 12-09-2015, 10:49 PM   #21
Fluxtasy
feed my pet
Fluxtasy's Avatar
90919-02229 are supposedly the RS coil packs. They are used parts so I decided to purchase 5 pieces as 1 would be a spare. rabbito is over there so maybe he could hook you up with a seller.
Old 12-10-2015, 12:30 AM   #22
invader166
Pumpman
Drives: 2019 Kia Soul EV Base
Interesting idea with a voltage booster. If there is a real benefit to doing this, then with a bit of tinkering, I think you can replicate the effect with a cheaper unit such as this.
http://www.amazon.com/gp/product/B00...rcuprojeele-20
It would all be a matter of finding an apropriate size that would deal with the heat that gets generated from the constant operation.
As a bonus, it's adjustable, so you can crank up the voltage even more if you're feeling brave.
Old 12-10-2015, 12:42 AM   #23
Fluxtasy
feed my pet
Fluxtasy's Avatar
I heard it is not recommended to go above 16v as it may damage or melt your plugs
Old 01-02-2016, 06:39 PM   #24
texascolt45
Drives: 2015 yaris
racecars run 16 volt batteries a lot in the us.no danger I think of burning up your plugs ha ha.
texascolt45 is offline   Reply With Quote
Old 02-02-2016, 01:17 AM   #25
rabbito
rabbito's Avatar
my E85 build is completed..you can check the "E85 Motor Build II" post from perfprmance modification section..
Sent from my ASUS_Z00AD using Tapatalk
Cosmetic: Toyota red emblem
Old 02-07-2016, 11:01 AM   #26
1nz revolution
Drives: 1nzfe
Okoda direct spark coil pack. Direct-port nitrous.
1nz revolution is offline   Reply With Quote
Can the Yaris run on E85? Anybody try it? auxmike DIY / Maintenance / Service 37 04-06-2019 07:52 PM
e85 kits chancellor6869 Performance Modifications 6 01-22-2015 09:36 AM
DAMN! Just put E85 in my car by accident... TheCutsman Fuel Economy Forum 9 08-12-2009 10:51 PM
Consumer Reports on Ethanol Driver General Yaris / Vitz Discussion 6 09-01-2006 11:21 AM
