Old 01-14-2013, 03:48 PM   #1
JustDidIt
JustDidIt's Avatar
Drives: '08G2T Prius
Sorry to carry on...
Originally Posted by JustDidIt View Post
Jetta set one this past year at 186mph but using a 1.4L with a turbo. Class - H/PS. The class is for production cars with engines of less than 1.5 liters that use forced induction. So not in the same class as the Prius...The all-new 2013 Jetta Hybrid marries a 1.4-liter turbocharged, direct-injection four-cylinder TSI® gasoline engine with a seven-speed DSG® dual-clutch automatic transmission and an electric motor. The combined output of the engine and electric motor is 170 horsepower, along with 184 pound-feet of torque.
LA AUTO SHOW
JustDidIt is offline   Reply With Quote
Old 01-14-2013, 08:57 PM   #2
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Just did the first fillup with the 1ZZ throttle body, and it hasn't hurt the mileage any.
37.8 mpg, all in cool 40-60 degree weather including a few 5th gear freeway miles. The idle is all fine tuned now and ready for some silicone. No chance of a dyno this week due to work. But next week has better prospects.
Old 01-21-2013, 04:55 PM   #3
tooter
play every day
tooter's Avatar
Just got back from Harry's Dyno Shop in the Valley...
Red: stock manifold + stock 1NZ FE throttle body
Blue: tooter manifold + stock 1NZ FE throttle body
Green: tooter manifold + Corolla 1ZZ FE throttle body
Here's a close up comparison between all stock, and the tooter intake with the 1ZZ throttle body...
Old 01-14-2013, 03:30 PM   #4
JustDidIt
JustDidIt's Avatar
Got Hybrid?
Barred from every one of Bonneville's 543 classes, the Toyota Prius creates a new one.
NOVEMBER 2004 BY AARON ROBINSON PHOTOGRAPHY BY JEFFREY G. RUSSELL
https://www.youtube.com/watch?v=fjKntmE4jlA
The man in the orange hat points a gloved finger down the track. I slide the stubby gear selector gently into drive and grip the wheel, ready to write racing history. But the digital display flashes "N," and that means the car's in neutral. I hit the shifter again, and again, this time a hard slap. N, N, N. I wave frantically at Jim Leininger, Toyota Team Greensport's crew chief. He scrambles through the passenger door, barking commands.
"Press the brake once!"
Brake pressed.
"Floor the gas three times!"
Once, twice, a third time.
"Press the brake again and try it!"
Nothing but N.
A frown spreads across the weathered face under the orange hat as it scans the half-mile line looking for another car to wave forward. Leininger punches the big dashboard button marked "Power." The digital screen goes blank.
"Damn computers," he mutters as the Toyota Prius hums and clicks and reboots itself.
Nobody ever had to reboot a Holley carburetor at Bonneville, but over a century of racing, that vast sun-baked, sodium-chloride playa has seen some changes. Overhead valves, overhead cams, fuel injection, turbines, diesels-they all made their debut here. Why shouldn't the next noteworthy first be a completely computerized car? The larval-shaped Prius has four of the little buggers onboard, and here at supercharged, open-piped, stand-on-it Bonneville, it sticks out like Rachel Carson at a lumberjacks' convention.
In 2004, the Southern California Timing Association (SCTA), which stages the Bonneville National Speed Week in mid-August on this dry salt lake in northwestern Utah, published a 188-page rule book for cars and motorcycles. It reads like a CIA cipher, full of codes such as XXO/ VGALT, for vintage (pre-1948) gasoline (but not blown) altered (or tweaked from its original shape or engine configuration) coupe powered by any flathead or overhead-valve V-8 or V-12 that isn't from a Ford but that does have a modified cylinder head (the record in that class is 154.103 mph, set by K. Young in 2001). There's also XXF/VGALT, which is the same but with a Ford flathead modified with an overhead-valve cylinder head (lucky M. Osborn has that record at 155.508 mph).
The book lists speed records in no fewer than 543 classes for cars and 370 for motorcycles. Show up in a Radio Flyer wagon, and they'll put your name in the book, it seems. Current and former Car and Driver editors hold three of those records, so it can't be very hard. But the Prius, on a red-hot track to set a record this year with 50,000 units sold in the United States, is barred from every class.
The hitch isn't the computers, exactly, but the fact that a Prius has two powerplants-one electric, one gasoline. A 1.5-liter DOHC 16-valve inline-four makes 76 horsepower to drive the front wheels. Plus, a 67-hp electric motor that Toyota calls the "motor/generator 2," or MG2, also drives the front wheels, sometimes by itself, sometimes in conjunction with the engine through a torque-splitting planetary gearset controlled by another electric motor (called the MG1) that also starts the engine and works as a generator to recharge the battery pack. No extension cords required; just gas it up and go-about 40 to 50 mpg in normal driving, somewhat less when you approach the stock top speed of 104 mph. A system designed to wring gasoline out of your daily commute might just wring more speed out of a small engine on the salt flats. This isn't just idle daydreaming for Toyota, what with Lexus about to launch the RX400h, a sport-ute that uses a hybrid system mainly to increase its 0-to-60 time rather than its fuel economy. Toyota's Bill Reinert, U.S. manager of the company's advanced technologies group, put the idea forward to demonstrate that hybrids are more than just slow-moving slugs for tree huggers. The first hybrid speed record might be a fine little feather in the corporate cap. He let it slip over red wine one night at the 2004 Detroit auto show last January. We let it slip that we were interested in the story.
Jim Leininger thinks more like a salt-flat racer. He's a field product engineer for Toyota, writes and produces his own songs, fought in Vietnam, and was tagged as the Prius's crew chief because he has run Bonneville with a variety of vehicles since the 1960s. He wondered if the Prius would beat the Bonneville record for 1.0-to-1.5-liter production cars (or H/PRO), which is 131.769 mph, set by one L. Monreal in a Volkswagen back in 1985.
A hybrid appeals to speed geeks in at least one way: Electric motors aren't affected by altitude. The salt flats sit at 4200 feet, thin air even on a day with a high barometer. When the barometer sinks, as it did during the 2004 Speed Week—all the way to an asthmatic 25.6 inches of mercury—an engine loses power. In that air, Leininger figured the Prius would generate a total of 125 to 130 horsepower at the starting line. Would the electric motor give it any advantage over a normal engine rated at the same output?
Did it matter? Since no one had ever taken a hybrid to Bonneville before, all Toyota had to do was show up and complete the timed mile twice. The average speed, whether it was 130 mph or 30, would be a record for hybrids. There was only one problem with the plan: The SCTA wouldn't publish a record without a class designation.
Bonneville's organizers have nothing against a car with two engines, especially one that only goes 104 mph. The Pigasus Racing streamliner run by C. Calvin Smith—a streamliner is basically a syringe on wheels—packs two Oldsmobile V-8s and goes over 180 mph. But when Leininger began researching how a Prius might get into the SCTA record book, the picture wasn't good.
Bonneville runs on rules the way the Southern Pacific runs on rails—any deviation causes an ugly mess. There simply weren't any rules for a hybrid because the SCTA has never hosted one on the salt flats in its entire 56-year history. The last time the SCTA created a new class was two years ago, just an engine-displacement addendum to an existing class. Minor stuff. The manuals are dusty on developing a class for a whole new propulsion system.
There had already been interest in and talk about a hybrid class, says SCTA rules advisory board member Dan Warner. "To keep this sport active, we have to take in new technology," he says. "The amount of support I got when I voiced the proposal, even from people I didn't expect would support it, was surprising."
But a hybrid class was just conversation, and some of the conversation scared the old hands, what with talk of 500-volt electrical cables and exotic battery packs that can explode in a lethal toxic cloud. Home-built electric cars, which have been clocked at over 250 mph at Bonneville, have some of those dangers. But they are required by the SCTA to have certain rudimentary safety items, such as a wood floor in the cockpit to attempt to isolate the driver and rescue crew from mega-zaps. A steel-bodied production hybrid like the Prius, where all the safety backups are factory installed—hidden under the floorboards or in microchip memories—"is a whole new ball of wax," says Warner.
The SCTA was waiting for someone to show up with one. Then the club's safety inspectors could learn a few things about the technology and write a set of rules. Then, maybe for the following year, those rules would go into the book, and anyone could show up and set the first record in the class. Maybe that meant the Prius's first runs at Bonneville would be academic, just unpublished data generated in the service of creating a class that Honda might easily dominate later with a five-speed Insight running a VTEC rat motor. Toyota wanted the first published record. While negotiations continued between Leininger and the SCTA, decision makers at Toyota huddled. If they didn't go, they might miss a historic opportunity to be the first hybrid to set a record at Bonneville. You don't get a second chance to be first.
The final decision came in June, just two months before the event. Chuck Wade, Toyota Motorsports technical group director, and his employees Rich Garver and Marty Schwerter had already done some of the necessary cutting and welding. As the Speed Week kickoff on August 14 loomed, Leininger also recruited his son, Mark, who has driven over 170 mph at Bonneville, to help swing wrenches.
First and foremost, the Bonneville Prius is a road sucker, dropped more than five inches from stock to minimize airflow under the already slippery body with its 0.26 drag coefficient. This was no simple matter of changing springs and bump stops. At the desired ride height, Wade and his crew discovered the inner constant-velocity joints of the driveshafts cocked at a dangerous angle, beyond what engineers in Japan considered safe. Since Wade planned to remove the differential and lock the left and right wheels together for better traction on the salt, a snapped CV joint could cause the Prius to veer wildly off the track.
The solution was to "clock" the transmission case, or rotate it relative to the engine, to bring the CV joints higher up, more in line with the wheel centers. To do that, Wade had to cut arches in the chassis for the repositioned shafts to pass through. He also installed a taller final-drive gear and reshaped the inner fenders to accommodate tires up to 29 inches in diameter. A larger tire equates to a taller top gear, so the bigger you go, the faster you go until your engine can't make enough power to overcome the increasing workload. With the Prius scrunched down and huge tires stuffed in, body motion had to be restrained—actually, stopped altogether. Wade installed custom Bilstein shocks and 3600-pound-per-inch Eibach springs in each corner, about 30 times stiffer than the stock springs and the next best thing to welding the axles directly to the car.
Bonneville's typical 100-degree summertime temps were a factor, especially in the car's inverter, where the 202 volts of direct current produced by the nickel-metal hydride batteries become 550 volts of alternating current for the electric motor. The smaller motor/generator, the MG1, might also roast during forced charges of the dead batteries, or when the pilot floors the gas and holds down the brake at the same time for about two minutes, using the engine to drive the generator through the planetary gearset until the multicolor dash display shows a full pack. The hotter the electrical components become, the less efficient they are. So out went the passenger seat and in went a 15-gallon tank to be packed with ice water right before the run. The water would be circulated by an electric pump through the inverter and electric motors. The 125 pounds this added to the car's curb weight didn't really matter; at Bonneville, weight is desirable. It increases traction and stability on the salt.
The 1.5-liter engine's block and head were stock Toyota Echo, or basically the same as the Prius but without the fuel-maximizing Atkinson-cycle valve-timing mechanism. The restrictive intake was from the Prius, as was the stock exhaust system. It was probably the only car racing at Bonneville ready for a California smog test. When the SCTA tech inspectors opened the hood, somebody in the crowd cursed and said, "It's a nuclear reactor!"
The tech tent at Bonneville is a notoriously prickly place, at times resembling a convention of southern sheriffs. Wrong answers and shrugged shoulders aren't tolerated. As the Prius was picked over by the clipboards, Leininger stood close, quick with a courteous answer. The car's sealed boxes, thick cables, and five-step process just for shifting into neutral were carefully explained, sometimes twice. "Look at it from their viewpoint," Leininger said later. "Some of these cars have been coming for over 50 years, and the rest of the time they sit in a barn with the salt eating away at them. If the tech guys aren't thorough, people get hurt."
Given that, the Prius's checkout went relatively smoothly, especially since many of Leininger's answers to questions such as what prevents the driver from accidentally removing the key were, "The computer won't let him." Soon the inspectors just nodded and echoed back, "The computer won't let him."
Still uncertain as to whether the car's runs would be published by the SCTA, the crew pushed the Prius into a three-hour staging line. There was ample time to meet some of Bonneville's 439 other pilots. The field seemed to break down into three groups: the salty dogs who return year after year in the same basic V-8 lowboys and T-buckets, the motorcyclists, and the screwballs.
Firmly in the latter category is Marshall Brasel from Landrew, Wyoming, who built a four-wheel, spear-shaped streamliner around a 1954 GMC firetruck engine. "I'm kind of a six-cylinder buff," he says, nodding toward a black cast-iron lump the size of a home furnace. He had just driven 192 mph, a personal record. It might have been faster but, "my leg was shaking so bad I couldn't hold down the gas pedal."
"In this kind of racing, people accept and love diversity," says Travis Heap, whose late father, Carl, was one of Bonneville's legendary screwballs. Carl Heap built and drove the Phoenix, a 1943 International mine truck fitted with a 4000-hp Detroit Diesel V-16 and an emerald-green swoosh of bodywork. It went 272 mph in 2003 on tires made for a Boeing 747.
"If they'll accept a bunch of crazy truckers from Oregon, they'll accept you," Travis said. And they did, the grizzled veterans wandering over in large numbers to inspect the Prius.
At the starting line, I could feel the gentle thump of our push truck, a Toyota Tundra, hitting the rear bumper bar. Push trucks are a tradition at Bonneville, used to help the rods and streamliners get rolling on their tall gear ratios. Toyota had learned in a hasty test session that the batteries would last long enough to accelerate the Prius from a dead stop all the way to 128 mph, but that was it. The "short course" at Bonneville for cars doing less than 175 mph is four miles long, with the third mile being the timed one. If the Prius accelerated on its own, it would be slowing down at the timed mile, out of juice.
Pushed by the Tundra to 40 or so mph—the transmission in drive and turning the MG1 to generate a top-off charge for the batteries—the Prius would spring from the Tundra's bumper primed with plenty of battery to complete the course. Plus, the big motor (MG2) would already be turning at its most efficient speed, about 3400 rpm.
I had already done one pass down the course on 25-inch tires, proving the system worked and recording a speed of 129.443 mph. There were even bigger grins all around when the SCTA's Warner informed us that the Prius's best speed of the week would be published in the 2005 book as a baseline record for a new hybrid class. That class will likely allow few modifications to the stock body and powertrain.
That means no hybrid streamliners, at least for now. It's the go-slow approach, Leininger explains. "The SCTA is an amateur club. It simply doesn't have the resources to protect someone against a Frankenstein."
Now the Prius had 26-inchers on the front wheels; Leininger wanted a time slip for over 130. The computers had other ideas. The Prius's traction-control system has no off switch, and it dials back engine power when it detects a speed difference between the front and rear tires. Wade had sized the front-wheel arches for larger tires but left the rear arches alone since only the drive wheels need to be bigger to get the ratio effect. The mixed tire sizes, though good for speed, would be perceived by the computer as a dire safety hazard.
Leininger had—or thought he had—a work-around. By stomping the brake and gas in a precise sequence, he could tell the computer to disable the traction-control system. It worked great, except that the computer now refused to put the car into drive.
"Hell with it, let's reset and see what happens," he said at last. The Tundra roared, the Prius lurched, the salt went tink-a-tink against the floorboards, and the tires whisked like two skis in snow. At 40 mph, Leininger hit the Tundra's horn, and I rolled onto the throttle. The Prius accelerated quietly but stoutly, running so straight and stable (and relatively slowly) that there was time to look around.
Speed is impossible to gauge out on Bonneville's vast, featureless saltscape. The bleached playa is so broad that only the peaks of some mountains can be seen above the horizon, which bends with Earth's curvature. Rainstorms drift across the landscape like ghostly jellyfish, sometimes blowing up towering walls of salt dust before them.
The radio clattered with the timing report. The Prius hit the measured mile at 130 mph, crested 131 a quarter of the way through, and exited the back door around 129. The official speed: 130.794 mph. Thunderstorms rolled in before even larger tires could be tested, but the car went 134.339 with its seams and lower grille taped up, an illegal modification in a production class but okay for a car with no class.
The traction control never did come on. Nobody knows why. Damn computers.
The Landspeed Prius ran a stock "Hybrid Synergy Drive" powertrain, which integrates a large electric motor with a 1.5-liter gasoline engine. The transmission final drive gear ratio for the gas engine was modified from the stock 4.23:1 to 3.2, while the inverter voltage was increased to 550 volts from 500 volts. The engine redline was also changed for optimum performance.
A transmission cooling system was added to the front passenger area to decrease the temperature of the inverter and electric motors and maximize efficiency. Regular ice was constantly added to the system to prevent overheating. Ambient temperature on the salt flats was nearly 100 degrees with nearly 100 degrees humidity.
Other modifications included the removal of the interior, the addition of a roll cage and lowering the suspension five inches for improved aerodynamics. The Landspeed Prius incorporates custom Bilstein shocks and Eibach springs. The inner fender wells were also altered to accommodate the lowered ride height.
To prepare for Bonneville's race environment the Landspeed Prius had a removable front tow bar and rear pushbar installed to assist the vehicle to the track.
ENGINE
* Gasoline Engine 1.5-liter, 4-cylinder, twin-cam, DOHC 16-valve
EFI with VVT-i, aluminum-alloy block and head
* Torque 97 lb.-ft. @ 4,200 rpm with Echo engine (Stock 82 lb.-ft @ 4,200 rpm)
* Horsepower 96 hp @ 5,800 rpm with Echo engine (Stock 76 hp 5,800 rpm)
ELECTRIC MOTOR/GENERATOR/POWER STORAGE
* Motor Type Permanent Magnet Synchronous Motor
* Electric Motor Power Output 50kW/1,2000 - 1,540 rpm
* Torque 295 lb.-ft. @ 1-1,200 rpm
* Battery type Nickel-metal hydride
* System voltage 550 volts maximum (Stock 500)
SUSPENSION
* Front Independent MacPherson strut suspension with
stabilizer bar Eibach Racing coil springs,
Bilstein shock absorbers
* Rear Torsion Beam with stabilizer bar, Eibach
Racing coil springs, Bilstein shock absorbers
* Tires 25 and 26-inch Goodyear Eagle Landspeed Record tires
Old 01-21-2013, 05:16 PM   #5
Congrats on that! With how much work you have put into this project it is great to see that nice little bump!
Old 01-21-2013, 05:24 PM   #6
tooter
play every day
tooter's Avatar
Thanks, CT...
Combining the tooter manifold with the 1ZZ throttle body really did the trick!
Now there's consistent gains from 3,500 rpm all the way up to redline... with absolutely no loss in driveability or gas mileage.
I'll be posting the YouTube dyno run video as soon as it's done uploading. This is what got dynoed today:
1ZZ FE 55mm throttle body throttle body
Simota SRI intake + 6 inch BLOX velocity stack + BLOX dry element air filter
tooter intake manifold
Weapon R 4-2-1 exhaust header
Micro Image Magnaflow center exit exhaust
stock ECU no tuning
87 octane gas
Old 01-21-2013, 05:25 PM   #7
JustDidIt
JustDidIt's Avatar
Looks good!! Nice to see those Dyno numbers. How does the car feel with the extra bump?
Old 01-21-2013, 06:02 PM   #8
tooter
play every day
tooter's Avatar
In normal driving it doesn't bog down like stock when you let out the clutch. and you can feel it come on stronger at around 3,000 rpm on up. The larger bore of the throttle body now better matches the increased flow abilities of the tooter. It feels lots more gutsy.
Now some of this effect is simply the fact that when you push on the gas pedal, the larger throttle body's butterfly is letting in more air for the same throttle position.
But the biggest difference is when the throttle is to the floor...
Old 01-21-2013, 08:08 PM   #9
JustDidIt
JustDidIt's Avatar
Wonder how it would handle a good AEM FIC tune. :)
Old 01-21-2013, 08:56 PM   #10
tooter
play every day
tooter's Avatar
Here's the video of today's dyno run...
http://www.youtube.com/watch?v=nDjz-3U7p5w
Old 01-21-2013, 09:53 PM   #11
^ Vtec really kicked in at the end yo!
Old 01-24-2013, 12:17 PM   #12
tooter
play every day
tooter's Avatar
Harry, at HK Motorsports dyno shop suggested tuning would increase the power but I won't be doing that. It already does good enough with the stock tune and regular pump gas... and I still want it to be able to pass the smog test. So I'll leave that for someone else to experiment.
Old 01-21-2013, 06:09 PM   #13
Nice dyno, especially for bolt on mods. Mad props to ya for doing this project. Makes the engine bay look much better too ;)
Old 01-21-2013, 07:51 PM   #14
etherdude
Drives: 2012 Yaris SE 5-speed
tooter,
So glad you got positive dyno numbers. I think the engine looks MUCh better without the plastic cover. I like to see the mechanical bits and pieces. Also, the whole thing looks much more "gnarly" with the DOHC valve cover showing instead of some stylized plastic.
Doug
etherdude is offline   Reply With Quote
Old 01-21-2013, 09:07 PM   #15
tooter
play every day
tooter's Avatar
Originally Posted by etherdude View Post
tooter,
Doug
Hey Doug,
Thanks, I'm really happy it makes more power... and most importantly with no loss of driveability or mileage. As much as I've been messing around with the Yaris, it's still our daily driver.
Yeah, I'm kind of liking the all aluminium look, too... especially as everything has the same even pearly matte finish.
Greg
Old 01-21-2013, 09:16 PM   #16
4/20 NEVER FORGET
Drives: 2008 Yaris HB MT
Now THAT is what I call some great HP/TQ gains. Not only is your peak HP better, but your TQ numbers after 4k rpms look great. I bet the car doesn't feel like it's running out of breath so much in the top end like these engines do right before redline.
Congrats on getting those numbers. You've worked hard for it! I'm glad it all worked out in the end, 110 whp isn't bad at all for a car that was rated 108 hp at the crank, with only bolt-ons!
Now I really can't wait to get a manifold and stick on this 1ZZ throttle body I have.
4/20 NEVER FORGET is offline   Reply With Quote
Old 01-21-2013, 10:11 PM   #17
tooter
play every day
tooter's Avatar
You're right... the engine pulls strong right up to the top now!
Just be sure to break off the epoxy and turn out that little idle screw about one turn before you even install your 1ZZ. It should work just fine as long as the butterfly can close enough for a nice slow smooth stable idle.
I'm so pleased how this has all worked out. The combination of the larger manifold and larger throttle body added up to doing more than each component could do alone.
...and I'm still not done yet. I have some other experiments I'm going to be trying out in the near future.
Old 01-22-2013, 10:06 AM   #18
4/20 NEVER FORGET
Long-tube header? Either way, I look forward to more updates.
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
