Old 01-17-2009, 12:11 PM   #1
yaris9876
Drives: yaris hatch 07 640K original m
what kind a weird plug is this
I buy NGK platinums and head out to the 07 Yaris(140K) and pop the top off
and go for the plugs and this weird thing is what I find...
what is it? it doesnt look like it needs replacing and if I had to what would these stupid
things cost..???The guy at auto zone didnt say a thing to me.. just gave me the plugs..
yaris9876 is offline   Reply With Quote
Old 01-17-2009, 04:35 PM   #2
yaris9876
come on some one give some info on this!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 01-17-2009, 04:41 PM   #3
Black Yaris
der Zeck
Black Yaris's Avatar
it is called a coil on plug set up... the ign coils sit on top the spark plugs
Old 01-17-2009, 05:27 PM   #4
ztrack157
Vroom Vroom Beep Beep
ztrack157's Avatar
Drives: Powered Roller Skate
Send a message via AIM to ztrack157 Send a message via MSN to ztrack157 Send a message via Yahoo to ztrack157
They (coils) don't need replacing. But man clean you engine of once in awhile. My car is flithy right now but you can eat off my engine.
Ever blown out an R-200 diff god know's I have
ztrack157 is offline   Reply With Quote
Old 01-17-2009, 07:32 PM   #5
welcome to 1999 :)
it's been more than 10 years toyota has used coil packs instead of spark plug cables.
Old 01-17-2009, 07:35 PM   #6
UTVitz
UTVitz's Avatar
Drives: Black Vitz Liftback
Yep, coil over spark plug-most newer cars have them now. They just make it a little more time intensive to change the plugs-no you don't replace them and I have yet to have one fail even on a 10 year old Jeep Grand Cherokee with 200K miles on it. Your car should have NGK "iridium" plugs, not "platinum" The iridiums are designed to last 120k miles-I don't recommend going this long even though Toyota does, but the car is long out of warranty by then-so I'm changing them at 60k miles. Iridiums cost $10-15 per plug from what I've seen. I'm not sure if the Yaris will run right on the platinums-try it and see. I did some research on iridiums-they have a much longer life that platinums-which are a step down in quality to the iridiums. Good luck.
Old 01-17-2009, 07:39 PM   #7
UTVitz
UTVitz's Avatar
Oh, if you do decide to clean your motor-don't get water down these holes or you'll ground out the plug-I did this to a Miata once. I clean my engine off with the black cover over the motor then I don't have to worry about it.
Old 01-17-2009, 07:53 PM   #8
Black Yaris
der Zeck
Originally Posted by IllusionX View Post
welcome to 1999 :)
coil packs and coil on plug are 2 completely different things.... cars with coil packs still have ign wires
Old 01-17-2009, 08:17 PM   #9
yaris9876
so I need what size mm deep socket for this???? And there is no way that platinums wont work..
iridium is expensive hype... there is so little iridium on there you could count the atoms.
its a drag you cant even get your head into over the holes to look into there..i would have seen the plug tops...
Old 01-17-2009, 08:24 PM   #10
Black Yaris
der Zeck
this is from alldata
Old 01-17-2009, 08:25 PM   #11
Black Yaris
der Zeck
platinums will work, they will not last as long... I hope you bought NGK/Denso plugs though
Old 01-17-2009, 08:59 PM   #12
mimelio
Drives: NONE
Anyone ever see Bosch Iridium plugs? They have the four ground electrodes
mimelio is offline   Reply With Quote
Old 01-17-2009, 09:03 PM   #13
Black Yaris
der Zeck
Junk... we sell them at work..... if you know anything about electricty, you know that the spark can only pass though one ground at a time, so why are there 4... and why does no other spark plug maker use it?
all a gimmick
Old 01-17-2009, 09:18 PM   #14
YarisSedan
Drives: 08 Yaris Sedan
Bosch will make your car run like crap. If you use a platinum they will not last as long and then your coil will eventually burn out as it tries to fire more power trying to jump the excessive gap. And they can run several hundred a piece. Just buy the oem ngk or denso iridiums. ANd return the platinums
Old 01-17-2009, 09:25 PM   #15
mimelio
Drives: NONE
Never ran them in Yaris just saw Bosch made Iridium plugs with four ground electrodes. Iridium is by far better than platinum...One more plug I saw was Pulstar http://www.pulstar.com/howtheywork.html they are expensive too.
Old 01-17-2009, 11:24 PM   #16
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
The 350Z crowd has been having coils burn out due to Pulstar plug use...
Old 01-18-2009, 06:13 AM   #17
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
I use regular NGK plugs for any Japanese car i own,they are trouble free and inexpensive,not sure how long they would last as i change them every 3yrs or 50k whatever comes first.For a small economical car like the Yaris i'd save the extra money by using regular plugs stay away from the expensive gimmicky spark plugs.
Old 01-18-2009, 09:57 AM   #18
Black Yaris
der Zeck
I am running Pulstars right now, with no problems in my Toaster
NGK is now the OE plugs for GM and Chrysler as well
radio wire colors & alarm wire color reference guide battleversiontc In Car Entertainment + Electronics (audio / video / alarm) 43 06-06-2023 02:12 PM
Viper Alarm Install gwasabi In Car Entertainment + Electronics (audio / video / alarm) 28 08-11-2010 02:57 PM
Plug Gap slvryaris DIY / Maintenance / Service 1 12-23-2008 10:02 PM
Toyota AUX plug w/ aftermarket radio? eight_heads In Car Entertainment + Electronics (audio / video / alarm) 20 09-07-2007 02:41 AM
Magnetic Drain Plug Source? blacksan DIY / Maintenance / Service 9 05-11-2007 08:01 AM
