Old 05-12-2009, 07:33 PM   #1
MGargano
Drives: 2009 Yaris Hatchback
09 Fog Light Install
I just want to make sure I'm doing this right before I finish so I don't have to tear everything apart again. I'm installing Micro Image fogs ( http://shop.microimageonline.com/pro...&productId=103 ) in an 09 LB and will be using the OEM stalk, not the supplied switch. I followed the supplied Toyota installation manual and I think I have a bit of a problem. Step #12 shows 2 wires (red/brown & red/white) connecting to pins 1 & 2 in the fuse panel but.... the wiring harness I received has 2 solid red wires. Does it matter which wires goes to which pin?
I used the headlight ground (near the air cleaner assembly) to ground the fogs and plugged in the supplied relay under the dash. Am I correct in assuming all that's left for me to do is install the OEM stalk? No more wiring necessary?
MGargano is offline   Reply With Quote
Old 05-12-2009, 07:43 PM   #2
Liu997
Drives: 2008 Red Yaris LB
You don't want your switch? I'll pay you for that since mines is busted up.
Liu997 is offline   Reply With Quote
Old 05-12-2009, 07:45 PM   #3
MGargano
I have the switch and the whole in-cabin harness. How much?
Old 05-12-2009, 08:13 PM   #4
Liu997
I only need the switch, I already have my fogs installed
Old 05-12-2009, 08:19 PM   #5
MGargano
Ok make me a reasonable offer for the switch and it's yours
Old 05-12-2009, 08:28 PM   #6
Liu997
check pm
Old 05-12-2009, 08:37 PM   #7
with an aftermarket kit, you can connect to either pin 1 or pin 2 (OEM brings right and left separately to each).
Don't forget about the FOG fuse as well. Other than that and the stalk you are good to go.
Old 05-12-2009, 08:48 PM   #8
MGargano
Is it a problem if I used both wires/pins?
Old 05-12-2009, 08:58 PM   #9
No problem - Makes it more OEM.
1 is right, 2 is left...
Old 05-12-2009, 09:11 PM   #10
MGargano
Ok good to know. Next up is the fog & cruise stalk and leather steering wheel
Part #s for Fog Light install? Can anyone who works for Toyota confirm? IsLNdbOi Cosmetic Modifications (Exterior/Interior) 73 12-23-2010 05:15 PM
Fog light install 07yaris_fe Cosmetic Modifications (Exterior/Interior) 10 07-20-2010 01:18 PM
Looking for the Toyota Fog Light install RocknRollRon DIY / Maintenance / Service 33 06-13-2010 06:46 PM
