Old 07-12-2009, 08:52 PM   #1
eii
Rides canyon walls
eii's Avatar
Drives: 1988 RX7 FC 10th AE
Hit wheel on wall, +camber/toe-out
OEM Style Wing Spoiler | TRD Axle-Back Exhaust | Megan Lowering Springs (1.5 f/r) | Simota Carbon Charger Intake | Python 871XP Alarm System | Aluminum Sports Pedal | 17x7 +42mm Enkei J10 Black w/ Silver Lip | 205/40 Falken Ziex-912 | NST Lite Crank Pulley Red | 1ZZ-FE Throttle Body | AMK Racing Header
eii is offline   Reply With Quote
Old 07-12-2009, 08:57 PM   #2
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
Most likely a bent lower control arm. Being the bolt-on part between the wheel hub and the subframe, it is designed to sacrifice itself to protect the subframe in just such a situation.
Old 07-12-2009, 09:23 PM   #3
eii
Rides canyon walls
eii's Avatar
Old 07-12-2009, 09:44 PM   #4
1NZYaris1
1NZYaris1's Avatar
here is the link too the factory repair manual
look under the suspension catagory for spec's and trouble shooting
http://www.yarisworld.com/forums/showthread.php?t=1768
or you can PM me your email and i can send it too you .
Old 07-12-2009, 09:56 PM   #5
Loren
What?
Loren's Avatar
Toe eats tires a lot more than camber does. As long as you don't have more than a degree or so of positive camber, it should be okay to drive for a while.
Good luck!
Old 07-13-2009, 12:35 AM   #6
eii
Rides canyon walls
eii's Avatar
Old 07-15-2009, 12:10 AM   #7
PhilD424
Drives: Red Yaris
Broken Axle?
-Phil
PhilD424 is offline   Reply With Quote
Old 07-22-2009, 10:49 AM   #8
eii
Rides canyon walls
eii's Avatar
Changing the lower control arm didnt help. I see some possible damage on the crossmember, I'm really hoping its not. I'll post pictures of it. Maybe its the shock/strut assembly? I dont know, its probably time to send it to a shop? I wouldnt know where to even begin with that..
Old 07-22-2009, 11:20 AM   #9
if you jack up the car, you would see what is bent, what is not. But i do not understand how you would have reassembled the whole thing without noticing anything bent?
the diagnostic is pretty simple. If you have camber, the problem is probably the control arm or shock/strut assembly or the ball joint. The ball joint comes with the control arm, this has probably already been fixed when you changed yours.
Old 07-22-2009, 12:15 PM   #10
Loren
What?
Loren's Avatar
A slightly bent subframe can be hard to see.
How far out of spec is the camber and/or toe? Those fancy camber adjustment bolts that a lot of people use to get 2 degrees of negative camber were designed for just this sort of problem. If it's not more than a degree or two out, you can correct it by either using an appropriate smaller diameter camber bolt or just slotting the lower strut bolt hole and adjusting it however you need to.
Old 07-22-2009, 12:27 PM   #11
When I had my accident last year more or less the same happened... Massive toe in and some positive camber. It was indeed the lower control arm, and the bearing in the wheel hub thing was also twisted, so that might be something you could check?
Old 07-22-2009, 11:05 PM   #12
eii
Rides canyon walls
eii's Avatar
Old 07-26-2009, 09:37 AM   #13
eii
Rides canyon walls
eii's Avatar
Old 07-26-2009, 11:33 AM   #14
TheSilkySmooth
TheSilkySmooth's Avatar
A frame shop is gonna have to look at this - cant tell by the photos. they have pickup points they can measure on the frame parts. They might be able to "pull" some parts straight with a come-a-long. You might have a damaged ball joint and dont want to drive much until its thoroughly check out- this can fracture and you'll loose the wheel off the car!
Old 07-27-2009, 10:02 AM   #15
eii
Rides canyon walls
eii's Avatar
Old 07-28-2009, 07:01 PM   #16
TheSilkySmooth
I dont think you can "bend" a strut without it being broken or binding. You prob moved the attacment collar up top which is usually adjustable. You could bend the unit body and the subframe tho. Have a frame shop look at it, they can check it and put the new struts in!
Old 08-16-2009, 06:49 AM   #17
Masteraal
Masteraal's Avatar
Drives: Black Yaris YRS 3dr Manual
BAHAHAHAHAAHAHAHA i did the same thing myself... however ive done a shitload of damage
all prices in AUD and done at the stealership
new struts 900$ steering rack 1700 tyre rods(?) 300$
hope this helps... mines getting repaired now... poor car! thank god for insurance :)
Masteraal is offline   Reply With Quote
Official YARIS Wheel & Tire Guide Black Yaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 403 08-10-2025 12:20 AM
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 02:41 PM
Steering Wheel Issue. Twistoffate0817 General Yaris / Vitz Discussion 8 01-31-2009 08:38 PM
Slightly damaged wheel aucorium Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 12-06-2008 08:06 AM
forged rims Vs. alloys red-jdm Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 07-23-2007 09:30 PM
