Old 08-07-2009, 06:56 PM   #1
2+2
Drives: 09 3Dr Manual
Does the rear antisway bar show?
Is the antisway bar considered a performance mod? Am I in the right place?
Anyway, does it show? I bought the 19mm one and it's white. Now I could install the sucker and step back and take a look but it's easier to hope you guys will take pity on a guy that's kind to old people, children and dogs and save him the trouble.
Btw, I see why Garm has such a good rep around these parts. He's a pleasure to do business with imo.
Edit: What I mean is do I need to paint the antisway bar black before I install it so it doesn't look goofy?
Just put the pedal down and let the devil take the hindquarters.
2+2 is offline   Reply With Quote
Old 08-07-2009, 07:26 PM   #2
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
Mine is red and yes I can see it but I'm on stock suspension too. I don't think it looks goofy.
Old 08-07-2009, 08:09 PM   #3
kurokoma-kun
Drives: 2007 Yaris HB
Mine is also red and it shows on my lowered car, but I don't mind.
my yaris, kurokoma-kun
Old 08-07-2009, 11:25 PM   #4
cruz-gsr
cruz-gsr's Avatar
Drives: 08 Yaris Lift Back
is your car lowered
cruz-gsr is offline   Reply With Quote
Old 08-08-2009, 02:02 AM   #5
2+2
Originally Posted by cruz-gsr View Post
is your car lowered
No, and I don't plan on lowering it.
Old 08-08-2009, 04:05 AM   #6
I think only the ends show. The bar itself is tucked up under the axle pretty well. The bar "faces" front so it's not like it's directly under the bumper. and, I suppose you could spray any "offending" white bits that you could see from behind after you installed it, as well.
Thanks for the kind words too.
Old 08-08-2009, 05:35 AM   #7
eii
Rides canyon walls
eii's Avatar
Drives: 1988 RX7 FC 10th AE
custom powder coat ftw!
OEM Style Wing Spoiler | TRD Axle-Back Exhaust | Megan Lowering Springs (1.5 f/r) | Simota Carbon Charger Intake | Python 871XP Alarm System | Aluminum Sports Pedal | 17x7 +42mm Enkei J10 Black w/ Silver Lip | 205/40 Falken Ziex-912 | NST Lite Crank Pulley Red | 1ZZ-FE Throttle Body | AMK Racing Header
eii is offline   Reply With Quote
Old 08-08-2009, 06:59 AM   #8
2+2
Ahhh. It faces front. It's a non issue then. Thanks.
Old 08-08-2009, 09:37 AM   #9
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
Only the ends are really obvious. It doesn't look bad at all.
Old 08-08-2009, 05:39 PM   #10
RedRide
RedRide's Avatar
Why would you want to hide a mod as great as the sway bar?
I got an UR bar from Garm and yes, you can see it when your a few feet away, eye balling it at the proper level, like from a car behind you, etc.
However, it does not look bad at all and it blends in well with the rear suspension. It's definately not "goofy" looking or anything like that.
I'm shure that the vast majority of people who see it do not not even realize what its or give it a second thought.
Old 08-08-2009, 06:05 PM   #11
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
I can easily see it when it my friends cars, they are all miatas tho =), but i think it looks pretty badass, matching with my red springs =)
Its a Chao!!!
Old 08-10-2009, 07:03 AM   #12
Sabretooth
37HSSV
Sabretooth's Avatar
Drives: '11 Mazdaspeed 3
Mine doesnt show too bad, If you get the Ultra Racing one, it should turn a shade of a dingy white/gray if you dont get the chance to clean the undercarriage much...
Old 08-10-2009, 11:08 AM   #13
mrbond
mrbond's Avatar
When driving behind my car, you can definitely see the whole thing. My lower tie brace, however, shows even more.
If your car is lowered or stock height, it'll look good no matter what. IMO, you don't need to go through the hassle of painting or powdercoating the part. Who cares if it shows, especially considering the kind of handling capability it provides?
Cheeeers!
- A Toyota Yaris
- A whut Yaris?
Old 08-10-2009, 11:49 AM   #14
My car is lowered and has a rear lip -- I'm guessing that hides it more. Glad we got more than one opinion.
Old 08-10-2009, 12:18 PM   #15
kngrsll
Apexing Egg!!
kngrsll's Avatar
i can see the bar pretty easily from behind. i like stealth, so i have thought about rattle canning it black like i did with the muffler.
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 08-10-2009, 12:34 PM   #16
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
Im lowered roughly 1.4-1.6 all around maybe more give or take~~ but i can ONLY see the two ends that bolt onto the lower shock bolt and the upper hole. You wont see the middle part of the bar, as Garm has said on here~~~ its tucked pretty good underneath..
If you crouch down you will see the bar then but minimally still.....
Old 08-10-2009, 12:43 PM   #17
supmet
Drives: 2007 4 Door Yaris
I'm not sure spray paint will stick that well to a powder coated bar, especially with all the wear and tear the undercarriage sees.
Old 08-10-2009, 01:43 PM   #18
DevilGirl
Drives: 09 3dr LB MT
Ok, for someone who doesn't know much about that many car parts (general maintenance, yes), what does the rear anti-sway bar do, and how is it installed?
(I'm sure there's another thread on this, so if someone could point in the direction of that thread, if they have it handy, that would be cool!)
DIY - rear sway bar [pics] cali yaris DIY / Maintenance / Service 199 07-28-2022 05:25 AM
Rockland Toyota/Scion Car show Zefoxe NY / NJ/ CT / PA 47 05-26-2009 08:16 PM
Ultra Racing 23mm Rear Stabilizer Bar Loren Performance Modifications 62 05-18-2009 07:20 PM
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-05-2008 11:37 PM
