Old 09-06-2009, 09:52 AM   #1
Tonavi
Tonavi's Avatar
Drives: 2007 Yaris HB
Acceptable tire sizes
I bought some new rims at the beginning of the summer, now I want to put snow/ice tires on the remaining steelies. The original tire size was 185/60/15 but I found a blowout tire sale on Blizzak tires but they only come in 195/60/15. Would a 10mm difference cause any problems?
I was able to put 185/60/15 Potenzas on 15x6.5 rims without any issues.
Tonavi is offline   Reply With Quote
Old 09-06-2009, 10:01 AM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
you want a skinnier tire for snow traction.
it would physically work on your car, but remember they're also taller than stock.
Old 09-06-2009, 01:51 PM   #3
RedRide
RedRide's Avatar
Actually, snow traction is mostly dependant on the type of tire and not the size,
Old 09-06-2009, 03:17 PM   #4
beeboy1917
Drives: 09 Yaris Sedan
I have the exact same dilemma this year with the exact same tire sizes. How much of an issue is it to be taller than stock? Are there any warranty implications?
beeboy1917 is offline   Reply With Quote
Old 09-06-2009, 04:14 PM   #5
supmet
Drives: 2007 4 Door Yaris
orly?
Go throw some 225 "snow tires" on and drive in 12 inches of snow in a yaris. Let me know how that works out for you
Old 09-06-2009, 07:47 PM   #6
RedRide
RedRide's Avatar
Are you "comparing apples and oranges"?
Given the exact same type of tires, one that is slightly wider will give less traction in snow? I don't thnk so.
Living in NY (for longer than I care to remenmber) I have found that the exact opposit to be true.
Old 09-07-2009, 07:53 AM   #7
fei
6.5" wide rims can cater up to 205 tyres if im nt wrong.
195 shd not be a problem to fit in.
fei is offline   Reply With Quote
Old 09-08-2009, 02:46 PM   #8
Tonavi
Tonavi's Avatar
So 195's would be safe even though the original steel rim was 5.5 inches? I'd think that 10mm wouldn't make that much of a difference.
Old 09-08-2009, 02:52 PM   #9
Tamago
Tamago's Avatar
Drives: UZJ100
yes you'll be fine.
but if you can get the same deal on 185's do that
Old 09-08-2009, 03:09 PM   #10
MUSKOKA800
MUSKOKA800's Avatar
Should work okay. The car may seem sluggish out of the whole due to taller final gearing. Highway mileage may improve slightly while city mileage could suffer.
Old 09-08-2009, 03:09 PM   #11
Tonavi
Tonavi's Avatar
Side question: Has anyone here had experience with winter tires? I've never personally used them before. The stock Potenza RE92s do okay in the snow, but I've had a few too many close calls to keep using them.
Old 09-08-2009, 03:20 PM   #12
Tamago
Tamago's Avatar
Drives: UZJ100
i've used them on my 1990 corolla when i lived in spokane. much improved handling in snow
Tire rotation: Does TPMS recognize tire position? jcdrotos Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 03-17-2011 02:00 PM
tire sizes doanutboi Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 08-28-2009 07:25 PM
Replacement Tire Sizes Sailr303 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 06-10-2009 08:40 AM
Tire diameter list grampi Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 06-04-2007 04:03 AM
