Old 01-11-2010, 04:05 PM   #1
detroiter
detroiter's Avatar
What could cause the difference in rear toe?
Well I went back up to the stock setup with the stock springs and shocks. After getting the alignment done, since I knew for sure the front's would be way off, the rears came back entirely within spec. But they varied a fair amount. The rear left was about .09 and the rear right was at .28. I'm not quite sure why their would be such a variance even though it's still within spec. Is that much difference in the two going to hurt anything? Has anyone elses rear toe specs came back similar before?
Old 01-11-2010, 04:48 PM   #2
127.0.0.1
what were the previous settings vs now ?
pothole, or a large bear, could have done that
Old 01-11-2010, 05:00 PM   #3
ddongbap
We aren't driving machines of precise engineering.
Old 01-11-2010, 05:07 PM   #4
markitect
I think that amount of difference could easily be factory tolerance. You shouldn't have any problems.
It wouldn't hurt to check the (rear)springs, make sure they are seated properly (they determine ride height, which will change your toe slightly).
markitect is offline   Reply With Quote
Old 01-11-2010, 07:03 PM   #5
Brentorius
Drives: 07 Mazda MX5 Copper Red
Are you still using the upper hole for the rear suspension?
Brent
Former Yaris Owner
Brentorius is offline   Reply With Quote
Old 01-12-2010, 10:51 AM   #6
detroiter
detroiter's Avatar
I lowered the arms to the lower hole, so everything's back to factory specs. According to the printout I got from the alignment place, .28 is still within tolerance. I believe it was from .03 to .31 that is tolerable. I just wonder why such a wide variance.
Old 01-12-2010, 11:36 AM   #7
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
probably because they adjusted it. <not sarcasm.
Old 01-12-2010, 11:41 AM   #8
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
Curious why you went back to stock?
Old 01-12-2010, 12:13 PM   #9
detroiter
detroiter's Avatar
I thought the rears are unadjustable?
And I went back to stock because driving on hard packed snow for a few months with relatively stiff springs and stiff shocks is not a very pleasant thing to endure lol. Perhaps in the spring I'll go back to the lowering setup.
Old 01-12-2010, 12:48 PM   #10
MUSKOKA800
MUSKOKA800's Avatar
After I installed my TRD parts I took it for alignment. I can't recall the spec.'s but my rears were not equal but were within OEM tolerance. The Tech suggested he could shim to make them equal but felt it wasn't going to be an issue. Many thousands of kilometers later the rears are wearing equally.
Old 01-12-2010, 12:48 PM   #11
my rear toe was 0.06" and 0.14" before adjustment. and 0.07 and 0.12 after.
There's always a light adjustments within the bolts.. My yaris have something in the front that is slightly out of spec.. i was told it did not affect anything.....
Another rear spring option! Honda Fit springs!! kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 10-23-2009 05:02 PM
Rear toe adjustment...shims?? ozmdd Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 10-15-2009 10:32 PM
Hyperco 5.5" single pigtail rear spring test kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 06-15-2009 10:11 AM
Difference b/w TRD Rear Sway Bar and these? IsLNdbOi Performance Modifications 8 11-11-2008 09:13 PM
