Old 04-23-2010, 02:33 PM   #1
8thcivic07
8thcivic07's Avatar
Drives: 2007 Honda Civic
Exclamation Fitment Question..help
Ok so my GF is looking at some wheels which are 16x7 +35 for her Yaris...shes lowered on Tanabe springs and I just need to know if she will have any issues with rubbing at all before we buy these. We were thinking about using her stock tires also.
Any help and input in appreciated! Thanks in advance.
8thcivic07 is offline   Reply With Quote
Old 04-23-2010, 03:47 PM   #2
minnyar
Drives: 2007 Yaris Sedan (5pd)
http://www.yarisworld.com/forums/showthread.php?t=5021
Looks like they would have to be pretty narrow tires 175-185's(don't know if they make them, sure doesn't look like it). The stock Yaris 16" wheel is 16x6. So you'd need spacers for a 16x7 wheel. Or go narrower.
minnyar is offline   Reply With Quote
Old 04-23-2010, 05:29 PM   #3
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
16x7 +35 with 195/16 or 205/16 is just fine with 45 or 50 series tires. Don't need spacers at all. In fact, don't add spacers or you'll make the wheel stick out of the fender and rub for sure. You can probably run your stock tires if you want - what's the specs on them?
Old 04-23-2010, 09:16 PM   #4
8thcivic07
8thcivic07's Avatar
awesome, yeah i wouldnt need a spacer i was just worrying about rubbing issues..id rather her run her stock tires on these so she can have a little bit of stretch....but anyways thanks again guys, ill make sure she posts pics when she gets them on.
oh also im not sure what her stock tires are, but i know they are 16s, just dont know what specs...she has them at her house and right now shes on a different set of wheels.
Old 04-23-2010, 09:44 PM   #5
kimona
kimona's Avatar
Drives: 2014 White VITZ
Stock/OEM tires are most probably 185/60/15's.
If you're dropped on NF's, and you run 16x7, ET35, I would suggest 195/50/16's. You'll be flush up front with this fitment, and may experience minor rubbing depending on the tyre you choose.
However, if you're dropped on DF's, this fitment will more than likely rub up front.
Old 04-24-2010, 02:09 AM   #6
Rubbing on the fender liners is less of a problem than rubbing on the metal fender edges, too. Decide if both are unacceptable. Most rubbing happens on the plastic liners, which can be trimmed.
Question about fitment. Phaeton Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 12-30-2008 10:29 AM
Wheel fitment question helladrift Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 12-02-2008 12:06 AM
Tire Fitment question Ryu Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 01-14-2007 01:47 AM
Yaris/Vitz fitment question MrMondayNite General Yaris / Vitz Discussion 2 11-07-2006 08:41 PM
