Old 05-05-2010, 01:00 PM   #1
i<3yaris
MPG Hog
Drives: 2007 Yaris Sedan
Door Lock Beep?
Okay, I just bought a 2007 Yaris at a Honda dealership yesterday. When I bought it, the keyless entry was not working. The car was still under Toyota's new car warranty, so I figured I would just go get the remote re-programmed. Well, I got to the Toyota dealership and they looked at the keyless remote, which looks identical to the key from my Corolla, and determines that it is in fact an aftermarket key. He also pointed out that it was not an engine immobilizer key. I did not think to ask at that point how it started the car if it was not one. They did program the key, and it works, however when unlocking and locking the doors, the car does not beep as my Corolla (2009) and RAV4 (2006) both do.
Is the car supposed to beep when you lock the doors via the keyless remote? Should I be concerned with the fact that a non-engine immobolizer key is starting the car just fine?
Thanks for your help!
i<3yaris is offline   Reply With Quote
Old 05-05-2010, 01:02 PM   #2
DKazzed
Drives: Mazda 5 GT 5MT
Only if you have a Toyota anti-theft alarm. Without it, the keyless does not beep.
DKazzed is offline   Reply With Quote
Old 05-05-2010, 01:05 PM   #3
i<3yaris
MPG Hog
Really? Cause neither my RAV4 nor Corolla have an alarm, but they both beep.
Old 05-05-2010, 01:14 PM   #4
b_hickman11
Drives: 08 Sedan
The Yaris does not beep and should not beep. Can you take a picture of the remote and post it?
Old 05-05-2010, 01:29 PM   #5
i<3yaris
MPG Hog
I cant take one and post it right now, but it looks exactly like this one, minus the trunk pop button. There is a Toyota emblem on the backside, but when I was at the dealership, the service guy showed me an authentic toyota remote and the emblem was slightly smaller on that one. He also showed me a bump in the un-cut portion right next to the plastic on the authentic one, which mine did not have.
Old 05-05-2010, 11:17 PM   #6
Revsson
AFAIK, the acknowledgement or answer-back function on the keyless remote
only flashes the hazard lights to tell you if the doors are locked or unlocked.
Check out page 46 of the Door Lock pdf:
http://www.etimago.com/yaris/repairm...oor%20Lock.pdf
The above is from the 2007 repair manual that etimago has posted at:
http://www.etimago.com/yaris/repairmanual/
CTScott can probably answer your questions about the immobilizer, but
I thought I read that the Canadian models had it and the USA models did
not, but I don't know that for sure.
BTW, here is the link for the Immobilizer pdf:
http://www.etimago.com/yaris/repairm...mmobilizer.pdf
CTScott would be the expert I presume.
Old 05-05-2010, 11:35 PM   #7
sickpuppy1
Drives: 2010 Yaris Sedan
My 2010 has immobilizer but does not beep. just blinks the corner markers. once for lock, twice for unlock. I have thought about putting a relay to beep the horn when it locks.
Old 05-06-2010, 01:41 AM   #8
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
Keyless entry does not beep, lights flash.
I think wanting the beep is very insensitive. I lived in an apartment and one of the tenants bought a jeep and after a week or so had an alarm installed. He would return 1:30 in the morning and set his alarm. The beep would wake me because I had a ground floor apartment facing the parking lot. I thought that person was very selfish and insensitive.
Old 05-06-2010, 08:45 AM   #9
b_hickman11
Drives: 08 Sedan
The previous owner could have bought the parts for the keyless entry and installed them by themselves. You can buy those keys on ebay.
Old 05-06-2010, 10:22 AM   #10
i<3yaris
MPG Hog
The car had keyless anyway with the power package. They just got a replacement remote for some reason or another.
Old 05-06-2010, 01:27 PM   #11
b_hickman11
Drives: 08 Sedan
Oh, OK. Well either way, the car should not beep and does not have an engine immobilizer.
Old 05-06-2010, 02:43 PM   #12
DKazzed
My 2008 Corolla didn't beep, when I asked my dealer why, they said it was because I did not go with the security system.
Old 05-06-2010, 03:16 PM   #13
Mistry
Mistry's Avatar
Drives: Red Yaris Liftback
I have an 07 HB and mine does beep. I had the dealer install the keyless when I first bought it. My remote looks different than the one you posted.
Mistry is offline   Reply With Quote
Old 05-06-2010, 03:36 PM   #14
i<3yaris
MPG Hog
The owners manual talks about engine immobilizer. Was it just an option for certain trims?
EDIT: I did some research and found my answer. It was a separate option.
Old 05-06-2010, 04:11 PM   #15
b_hickman11
Drives: 08 Sedan
In Canada there is a law that all cars must have it therefore their Yaris's come with it. Most 2007 Yaris in the US did not have the engine immobilizer. If you can take your key to Wal-Mart, have a copy made, and start your car with the copy, you do not have the engine immobilizer.
Old 05-06-2010, 04:11 PM   #16
b_hickman11
Drives: 08 Sedan
They probably installed an aftermarket kit.
Old 05-06-2010, 05:51 PM   #17
DandiDani
DandiDani's Avatar
i have an alarm on my 09' lb and it doesnt beep and my key is the same as that one ^
Old 05-08-2010, 03:15 PM   #18
enviri
enviri's Avatar
Drives: 2010 Yaris
i have a '10 and my alarm beeps....70% of the time.
Disable beep when driver door open and key in ignition fmicle DIY / Maintenance / Service 7 05-03-2018 05:30 PM
Seat belt reminder warning Beep Jord DIY / Maintenance / Service 28 04-09-2009 08:37 AM
How do you make keyless beep on unlock and unlocking the car. marcus General Yaris / Vitz Discussion 7 04-17-2007 09:53 AM
Annoying beep clayky General Yaris / Vitz Discussion 4 01-30-2007 03:34 AM
How to disable the beep? (ASAP) Rahxephon General Yaris / Vitz Discussion 16 06-05-2006 05:03 PM
