Old 06-25-2010, 12:32 AM   #1
marlondog
Shut your fricken suck!!!
marlondog's Avatar
Drives: 07' liftback
Tokicos in the front,stocks in the rear?
Have any of you out there switched your front shocks to an aftermarket brand, but left them stock in the rear. Would this be a good idea? I'm currently riding with Tokico Blues and Tein S-techs, and wanted to know if anyone out there has done any mixing and matching.
marlondog is offline   Reply With Quote
Old 06-25-2010, 08:57 AM   #2
I have koni yellows in the front and TRD sportivo in the rear. Work for me. But it would be nice to have adjustability in the rear as well.
Old 06-25-2010, 01:10 PM   #3
evo165
evo165's Avatar
Drives: peArL yAvItZ!!
Send a message via MSN to evo165
Your current full tokico blue with S tech is already a very good combo set up, which is my current set up as well. IF you wanna try it, i will rather u put on the stock front & blue in the rear to further increase car steering. By having the front blue & stock soft rear, your car somehow will reduce oversteer.
1NZ-FE Yaris with JDM RS front & rear bumper | JDM Vitz RS taillamp | JDM Vitz window visors | JDM Vitz Netz logos | JDM leather steering wheel & shift knob | 4k HID | K&N panel filter | Fujitsubo Wagolis exhaust | NST 10% crank pully | KYB Excel-G shocks | NF210 Springs | Cusco 4 points lower arm bar & Type OS top struct bar | RZCrew sub-frame collars | Ultra Racing 19mm rear sway bar & rear lower & center braces | PG Rear 13mm hub spacers | Exzess 2-pot calipers with 282mm rotors | Runstop Rear Disc | SSR Semi-Forge Type F 15" rims | Michelin Pilot Sport 3 195/55/15 tyres
evo165 is offline   Reply With Quote
Another rear spring option! Honda Fit springs!! kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 10-23-2009 05:02 PM
Hyperco 5.5" single pigtail rear spring test kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 06-15-2009 10:11 AM
Ultra Racing 23mm Rear Stabilizer Bar Loren Performance Modifications 62 05-18-2009 07:20 PM
