Old 10-26-2010, 04:56 PM   #1
jamal1984
The Beautification of Car
Drives: Toyota Yaris S
how do you remove this brake Drum?
this is on my gf chevy aveo, and yeah i been banging this thing for like hour, still no result.
Id been googling for repair manual, even under daewoo but nothing come up.
Old 10-26-2010, 05:14 PM   #2
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
I'm guessing you pop that center cap off and there will be a large nut holding it on.
Old 10-26-2010, 05:14 PM   #3
SailDesign
Drives: .
I think you'd get further if you at least removed the dust-cap, and some of the mechanical sh!t inside it. Things that wheels are bolted to do not usually come off with just a few bangs from a hammer.....
<sigh>
Old 10-26-2010, 05:47 PM   #4
.Kevin.
I ain't even mad
.Kevin.'s Avatar
Chevy aveo is the problem help her fix it lol
Old 10-26-2010, 06:00 PM   #5
DARK AGE 53
Drives: 2009 Yaris Onyx
I vote removing the dust cap also.
DARK AGE 53 is offline   Reply With Quote
Old 10-26-2010, 06:43 PM   #6
jamal1984
that's what i thought guyys, but i'm trying to use all kind of stuff to pull it out, turn it in clockwise and counter, but that dust cap feel like gorilla glue in there.
Old 10-26-2010, 07:06 PM   #7
sickpuppy1
Drives: 2010 Yaris Sedan
Well, the first thing I did was to Google " Removing brakes drums from chevy aveo" and found this, http://www.aveoforum.com/forum/f108/...ke-drums-7482/
Yes, I know, I'm a smart ass,lol
Old 10-26-2010, 07:59 PM   #8
rningonfumes
rningonfumes's Avatar
Drives: Yaris Sedan 5MT
Have you tried releasing the brakes (after making sure the car won't go anywhere), then taking a mallet or hammer and giving it a few good wacks?
The next resort after that would be to take the appropriate size bolt that fits into that hole on the right-middle of the first pic and forcing it off that way.
Old 10-26-2010, 08:18 PM   #9
p123456789
Drives: 07 lb jeep tj
use a small screwdriver and a hammer, pound the screwdriver between the dust cap and the drum and pry it out there will be a cotter pin with a nut behind that. After removing the cotter pin and the nut the drum should come off.
p123456789 is offline   Reply With Quote
Old 10-26-2010, 08:23 PM   #10
silver_echo
ekodrvr
silver_echo's Avatar
correct, that is what i would do as well... don't pound too hard, but yes...
i like this smiley...
silver_echo is offline   Reply With Quote
Old 10-26-2010, 08:35 PM   #11
.Kevin.
I ain't even mad
.Kevin.'s Avatar
Anyoen notice by the way how it says BAD on the left side.
Old 10-27-2010, 03:34 AM   #12
FSANE
FSANE's Avatar
Drives: 07 4d yaris and 02 Trans Am
make sure the E-brake is off.
02 T/A AUTO Metalic Silver. 07 Yaris M5.
Best ET is 11.13 @ 120 MPH with 1.47 60FT
11.13 sec vid
BurnOut Vid
FSANE is offline   Reply With Quote
Old 10-27-2010, 04:23 AM   #13
djct_watt
Drives: 2010 NCP91 5spd
^I was guilty of making that mistake once
djct_watt is offline   Reply With Quote
Old 10-27-2010, 04:50 AM   #14
FSANE
FSANE's Avatar
me too
11.13 sec vid
BurnOut Vid
Old 10-27-2010, 07:49 AM   #15
jamal1984
thank you all for the tips will try again later today, and yes what is that BAD red word mean?
Old 10-27-2010, 08:28 AM   #16
firemachine69
School'er of hard knocks
Drives: Silver Yaris 4dr. HB
Manufacturing code.
I must say, that drum looks to be in mint shape. Usually they're rusty a couple days after delivery.
Last I recall, you had to remove the axle nut (underneath the grease cap) to remove the drum, but I may be thinking of another car...
firemachine69 is offline   Reply With Quote
Drum brake upgrade xbalance Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 04-19-2009 05:16 AM
