Old 12-01-2010, 07:24 PM   #1
Lorenzo1950
Drives: 2010 5 door Hatchback
speaking of gears
Why did Toyota opt for the squiggly gear shift for the automatic transmission instead of the old straight line? I am finally getting used to it but it still looks strange to me. Is this design for safety reasons?
Lorenzo1950 is offline   Reply With Quote
Old 12-02-2010, 10:31 PM   #2
echaru
PsychMobile
echaru's Avatar
Drives: '10 Yaris 5Dr Blazing Blue
Don't know, but it's awesome that I can change the knob by just unscrewing it.
echaru is offline   Reply With Quote
Old 12-03-2010, 12:21 AM   #3
djct_watt
Drives: 2010 NCP91 5spd
Some people are morons when it comes to driving, and despite a brake-lock and a shift button, some people will switch into the wrong gears. . . like Park or Reverse by accident.
The best modification you can make is between the steering wheel and driver's seat.
djct_watt is offline   Reply With Quote
Old 12-03-2010, 10:13 AM   #4
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Drives: MM 09 Yaris 5 Dr LB "Click"
The design makes it easier to get the selection you want and not the ones you don't.
For example, from Drive you can push straight ahead and get N but you can't get to R without side movement, so its easy to get N at lights and in an emergency.
From D you can also simply bat the lever to the left and get 3 which is an awesome feature. A lot of us use 3 frequently to get maximum DFCO and engine braking and frequently shift back and forth from D to 3. All are easily accomplished with out fear of getting the wrong gear.
AWESOME setup IMO. The Yaris has the best conventional auto I've ever driven, both in function and layout.
And yes as a nasty side affect it's safer! :)
"The howl was the sound of God’s casting pot, the morphing of my cells into shape, the forming of oceans out of molten premordial plasma. And I could feel it. I could cry for it. I could cry with it."
-The Fitful One
R2D2 is offline   Reply With Quote
Old 12-03-2010, 10:36 AM   #5
teddy
Drives: 2008 5-door hatchback
Send a message via MSN to teddy
+1000 to what R2D2 said.
I bump it into 3 frequently when decelerating for DFCO and reduced break wear. I use N at long lights when it's safe to take my foot off the break (often in combination with the handbrake).
Being able to bump it into N has been helpful in slippery conditions. I don't need to worry about holding any button down or how far I move it forward because it would be difficult to accidentally move it to R.
There have been some other cars I've been eying by Honda and the shifter would definitely be something I'd miss.
It's not even just the Yaris, Toyota has a similar layout on the Matrix and Sienna - probably others.
teddy is offline   Reply With Quote
Old 12-03-2010, 10:42 AM   #6
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
I love the shifter on the Yaris. It makes it easier for me to shift by feel instead of having to look.
Old 12-03-2010, 10:52 AM   #7
SailDesign
Drives: .
It's so you auto-only guys can feel like you're playing with a real shifter.....
Old 12-03-2010, 04:25 PM   #8
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
Well played, ol' chap!
Old 12-03-2010, 05:01 PM   #9
djct_watt
Some people hate the zig-zag shifter. . . many in fact. But I love it. Especially the ones that are shaped like an H and have 6-7 positions, with neutral in the middle.
Looking for Yaris Manual Trans Differential Gears... JMD83 Willing to Buy by private party 0 09-06-2010 07:09 PM
yaris 2009 MMT-problem in shifting gears. matanfr DIY / Maintenance / Service 8 06-30-2010 01:37 AM
Stiff gears after a while juxtapozed General Yaris / Vitz Discussion 10 05-05-2010 04:37 PM
2004 yaris hatch, 2nz-fe, DFCO in all gears? toyo Fuel Economy Forum 11 06-26-2009 02:21 PM
