Old 12-17-2010, 07:22 PM   #1
Rnankoo
Rnankoo's Avatar
Drives: Toyota Yaris meteorite silver
HIDs
ran into a little problem... Im not to sure where to connect this wire thats in my hand i think it goes to the battery but idk
Rnankoo is offline   Reply With Quote
Old 12-17-2010, 07:25 PM   #2
Rnankoo
Rnankoo's Avatar
there for the head lights H4 also the h11 has the same ones also
Old 12-17-2010, 08:00 PM   #3
severous01
you should have a bulb adapter harness...unless you bought a cheap kit...or you can make a harness/relay setup and run power/ground to the unit. or, you can use the headlight harness adapter to power the unit but it's not as reliable.
dont mix up power ground or you could chance blowing the unit. you can use the headlight harness to power the relay and run the relay directly to the unit....is how i'd do it.
Old 12-18-2010, 10:36 AM   #4
Rnankoo
Rnankoo's Avatar
thanks for the replyi got it from garm so u know its good stuff the only thing is is that the h11 hid fogs didnt come with a relay cord or anything im not sure if there supposed to but im gonna shoot a email to garm
Old 12-18-2010, 06:27 PM   #5
severous01
nah. you plug the factory harness in there if it fits. otherwise you'll need a harness adapter.
Old 12-18-2010, 08:20 PM   #6
Rnankoo
Rnankoo's Avatar
i think its supposed to go into a relay and connect to the battery it has a + and a - symbol on the other side
Old 12-18-2010, 08:22 PM   #7
Rnankoo
Rnankoo's Avatar
did anyone get the hid kit for the fogs from garm i check to see if it was in the DIY section but it wasnt
auto depot headlights + HID's? thebarber Cosmetic Modifications (Exterior/Interior) 42 01-19-2012 05:56 PM
installed some 3000k HID's thebarber Photo-Video-Media Gallery 17 01-22-2010 09:45 AM
Where is my DRL Module......? Help With HID's The Architect DIY / Maintenance / Service 6 05-20-2009 10:21 AM
DRL and HID's? dimsum69 Cosmetic Modifications (Exterior/Interior) 5 01-12-2009 03:30 PM
NEW HIDS 10000k!!!!!! elsteverino889 Cosmetic Modifications (Exterior/Interior) 69 01-26-2007 12:12 PM
