Old 12-23-2010, 04:23 AM   #1
3dr5speedblk
StickShift
3dr5speedblk's Avatar
Drives: 2010 Yaris HB
Hella supertones
Waiting for warmer weather to install my Hella supertones horns 118db
LOUD!! Bought for my GTI never got around to install!!
Has anyone installed these ? Do I need to use the relay? That comes with them.
http://www.amazon.com/Hella-SuperTon.../dp/B000CRZXPI
"Live like there's no tomorrow"
3dr5speedblk is offline   Reply With Quote
Old 12-23-2010, 06:17 AM   #2
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
i would use a relay personally.. esp if it came with one.. basicly relays allow you to use less current to switch it on but use full battery power to make the most noise possible out of that horn. if you wire it up straight from your battery, to ur switch to your horn and then ground, you might melt the switch probably and maybe a wire.. relays are just safer and more reliable
Old 12-23-2010, 06:58 AM   #3
Hella's website shows them as drawing 12A (which seems to be typical for most of Hella's horns), so you would need the relay, as the stock horn driving circuit is only rated for 10A.
Old 12-23-2010, 04:03 PM   #4
severous01
you answered your own questions...
the hella is higher rated and will blow the fuse if it draws full current. and if the fuse is there to protect the circuit from more than 10 amps...then the wires are rated at 10 amps as well...and so on. so, if you put a 15a fuse in there you'll likely cause problems.
Old 12-23-2010, 04:07 PM   #5
That was my answer to his question...
Old 12-23-2010, 04:13 PM   #6
i never used a relay...
i had them on 3 cars before they both died (rust + salt = dead horns after 6 years)
Old 02-26-2011, 09:10 PM   #7
3dr5speedblk
StickShift
^Yeah,Wired it right off the old one!! Ground em to the frame!
These things are LOUD! Gona wake up Granny at the stop light!ha..ha..
Put some Polarg M4 super white bulb (park light) in while i had the bumper off
Looks HID!
Old 08-03-2011, 11:23 AM   #8
dzcab
Drives: 2011 3Dr Hatch
I just purchased a set of Hella Supertones and decided to change the front from Red to Green. I am planning on installing this weekend, but the instructions that were sent with the horns is somewhat confusing. It has several ways to hookup with relay depending if the horn is hooked up positively or negatively. I am not sure which way I should hook them up. I definitely want to hook up with relay as this is safest way. Can anyone tell me how they hooked them up. Also, Is is necessary to remove the whole front bumper to put these horns in. Here is a pic of one of the horns that I just painted.
Sorry if pic comes out to big not sure how to resize.
dzcab is offline   Reply With Quote
Old 08-03-2011, 11:47 AM   #9
Vioz
Drives: 2008 Yaris Sedan
Send a message via AIM to Vioz
I want it, my air horn doesn't work anymore, it sounds like a dying duck whenever I honk....its pathetic.
a.k.a. "Aothachos"
Vioz is offline   Reply With Quote
Old 08-03-2011, 11:50 AM   #10
^ you gotta post a vid of that.
Old 08-03-2011, 11:59 AM   #11
dzcab
Vid of what?
Old 08-03-2011, 12:21 PM   #12
Vioz
I deff will during my lunch at work :D lol
a.k.a. "Aothachos"
Hella taillights installed Brian Cosmetic Modifications (Exterior/Interior) 20 09-18-2011 11:41 AM
Hella Twin Supertones lilredrocket Cosmetic Modifications (Exterior/Interior) 40 03-06-2011 05:44 AM
MI Hella taillights for the sedan big lo General Yaris / Vitz Discussion 2 06-16-2010 11:09 PM
HELLA HORN INSTALLATION jaimico In Car Entertainment + Electronics (audio / video / alarm) 3 02-08-2009 05:09 PM
Hella 118db horns Galavoxx Cosmetic Modifications (Exterior/Interior) 31 03-27-2007 11:36 AM
