Old 12-26-2010, 10:13 PM   #1
dwoodpub
Drives: 2005 Yaris Hatchback
2005 Ignition sticking
I bought my 2005 Yaris new. From the first month or so, every now and then, when I turned the ignition on, it would stick and just keep turning like it was trying to start. It finally would start but it keeps doing it. Again, it only does it every now and then.
dwoodpub is offline   Reply With Quote
Old 12-26-2010, 10:34 PM   #2
big lo
big lo's Avatar
Drives: 2007 VIOS
Sound like a faulty Starter, you should get new one bro
Old 12-26-2010, 10:37 PM   #3
brg88tx
Drives: 07 Yaris Sedan, Auto
oh really? a 2005 yaris in tenessee?
brg88tx is offline   Reply With Quote
Old 12-27-2010, 01:34 AM   #4
swidd
Drives: Yaris HB
The Yaris has a feature that it will continue to crank for up to 10 seconds automatically, even if you let go of the key from spring-loaded START back to IGNITION. In essence, you can just "tap" the ignition, and the Yaris will determine how long to apply the starter for the engine to start.
Seeing as you've owned the Yaris for 5 years... eh? Maybe the problem is something else..
Old 12-27-2010, 01:40 AM   #5
yaris2010RS
yaris2010RS's Avatar
there was another thread on this issue; every time the member would depress the clutch fully it would try to crank again
i dont recall if that issue was ever resolved but it was said to remove the relay and bang it on something hard (or replace it) as something inside is sticking
on the other hand i am assuming u mean the starter motor continues to crank the engine even after the engine starts, like said above, the yaris has an "auto" start feature, all u have to do is move from the "on" position to "start" position with the key for a second and the starter will continue to crank untill the engine catches.
Old 12-27-2010, 01:47 AM   #6
yaris2010RS
found it
http://www.yarisworld.com/forums/showthread.php?t=30758
and like was said by CTScott (if anyone knows how to fix an electrical issue, it would be him)
My bet is on the ST relay (in the under hood fuse panel). Pop it out, tap it on a hard surface, put it back in, and see if the issue stops. If so, replace the relay, as once the contacts start sticking, they will keep doing so.
the other member's would constantly crank, but if urs are only holding for a little longer then i would assume the sticking would continue
Old 12-27-2010, 06:22 PM   #7
dwoodpub
At least everyone in this forum is alert. I feel like an idiot. I have a 2005 Tacoma and have been posting stuff about it. I meant to say the Yaris was a 2007. Sorry again!
Old 12-27-2010, 06:24 PM   #8
dwoodpub
Sorry- I meant 2007
I meant 2007. Sorry.
Old 12-27-2010, 06:44 PM   #9
big lo
big lo's Avatar
Drives: 2007 VIOS
Originally Posted by yaris2010RS View Post
found it
yes CTScott is the man in that area
Old 12-27-2010, 06:44 PM   #10
big lo
big lo's Avatar
Drives: 2007 VIOS
ok D man we got you, 2007, lmao
Old 12-27-2010, 10:49 PM   #11
dwoodpub
Thanks
Thanks for the response. I meant to say it is a 2007. It started doing it not long after I bought the car new. Every time I took it to the dealer it wouldn't do it.
Old 12-27-2010, 10:52 PM   #12
dwoodpub
Thanks everyone. I will check out the link.
Old 12-27-2010, 10:58 PM   #13
dwoodpub
Thanks
Thanks for the reponse. My Yaris is an automatic, if that makes a big difference.
[QUOTE=yaris2010RS;543730]there was another thread on this issue; every time the member would depress the clutch fully it would try to crank again
on the other hand i am assuming u mean the starter motor continues to crank the engine even after the engine starts, like said above, the yaris has an "auto" start feature, all u have to do is move from the "on" position to "start" position with the key for a second and the starter will continue to crank untill the engine catches.[/QUO
2005 Rear Undercarriage Pic Needed? gapi Cosmetic Modifications (Exterior/Interior) 0 09-21-2010 05:52 PM
FS: Motec M4 Standalone ECU w/ Ignition Expander Biggie™ Items for Sale by private party 6 10-20-2009 02:36 PM
Moving the Ignition To The Left? MadMax Cosmetic Modifications (Exterior/Interior) 4 10-02-2009 11:57 PM
