Old 03-14-2011, 05:47 PM   #1
Crashingtehwarehouse
Drives: '07 Yaris 3D
Console/Radio Illumination
Hi all,
I just purchased an '07 Yaris 3 Door Automatic and find it odd that I can't see any of the console buttons and knobs at night. I've tried messing with the brightness wheel next to the steering column, but nothing. And the only thing that lights up on my radio is the display.
I took it back to the dealership today, and my salesman said that's normal. Is it? Because it certainly seems to be annoying.
Crashingtehwarehouse is offline   Reply With Quote
Old 03-14-2011, 05:57 PM   #2
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
That's not normal. Usually people with this issue do as you did and turn up the dimmer wheel. If that's not doing it for you then I'd say something is wrong.
Old 03-14-2011, 06:13 PM   #3
Yeah, I think it's weird too. I've had a lot of cars before, and none of them were completely dark like this one. Sad
Old 03-14-2011, 07:10 PM   #4
bizzlebaby
bizzlebaby's Avatar
Drives: 4 Dr 07 Sedan
there is a setting on the dimmer wheel that will turn all the lights down... perhaps yours is set to that position... try turning it forcefully downwards... i know sometimes at night i purposely drive with my dash and console lights off
bizzlebaby is offline   Reply With Quote
Old 03-14-2011, 10:05 PM   #5
If it's not the dimmer rheostat position, check the MET and GAUGE fuses in the under dash fuse panel (literally under the bottom of the dash, by the hood release lever). The prior owner may have had an aftermarket radio installed and popped one of the illumination related fuses when deinstalling it.
Old 03-15-2011, 02:47 PM   #6
Nope, that was the first thing I tried. The dimmer rheostat does absolutely nothing. It's like it's been disconnected or something.
Old 03-15-2011, 02:50 PM   #7
You mean popped as in it's not seated properly or popped as it the fuse is blown? And how will I know which fuse is which?
Thanks
Old 03-16-2011, 11:03 AM   #8
Idahotom
Drives: 2008 5 sp. LB
You sure you have the lights turned on, and arn't just driving around on the daytime lights? That's what I did the first 200 miles when I picked up my '08! I too was puzzeled by the lack of lighted dash controls.... until I figured that they go on just fine when you turn the headlights on!
BTW, when driving at night using just the daytime lioghts, you have NO taillights, that seems like a bad idea.
Idahotom is offline   Reply With Quote
Old 03-16-2011, 12:07 PM   #9
Thanks
Popped as in blown. The fuse cover has a diagram on it that shows which fuse is which.
Old 03-18-2011, 08:03 PM   #10
Yaris
Yaris's Avatar
Drives: 2010 LB Meteor Metallic
So take it to the Service dept.
Yaris is offline   Reply With Quote
Old 11-29-2011, 11:33 AM   #11
I've been meaning to come back and say, you were right. I had no idea, for the longest time that I had to actually turn on the lights. I've never had a car that I had to do that with, so never thought to try it.
Thanks!
2010 Yaris 3DR LB: Backup Lamp Illumination Distance msmitka General Yaris / Vitz Discussion 21 12-27-2011 01:25 PM
Light Bulb Numbers For Interior Illumination privateyeblckbx Cosmetic Modifications (Exterior/Interior) 0 05-16-2010 04:59 AM
part #'s for interior illumination package bladesmith6 Cosmetic Modifications (Exterior/Interior) 4 05-03-2010 11:33 AM
Tachometer Illumination Thirty-Nine DIY / Maintenance / Service 4 05-29-2009 04:59 PM
Tach Illumination wire Liu997 DIY / Maintenance / Service 6 05-29-2009 11:11 AM
